SolaraGuy.com • View topic - Do I need a Camber Kit???
Postby DvS One » Thu Jul 03, 2003 9:02 pm
Hey Guys,
I was wondering if any of you guyz could tell me if i should get a camber kit for my 99 solara. b/c im getting 18's and lowering my car with eibach springs. Do I really need the camber kit? and if i do what brand is good for the solara..........
thanks
Minh
DvS One
Regular SolaraGuy
Regular SolaraGuy
Postby impactX » Thu Jul 03, 2003 9:47 pm
You shouldn't need one.
Just do an alignment.
impactX
Postby Yanks0114 » Thu Jul 03, 2003 10:26 pm
our cars do NOT need camber correction kits regaurdless of what any mechanic tells you
Postby Turbosolara » Thu Jul 03, 2003 10:47 pm
If you have heavy stereo in the trunk, then you do have negative cambe in the rear. The shop charge me $40 dollars each side to modify the rear axle carrier. There are two bolts connect the rear shock to the wheel hub. They make the bolt hole from this shape ( ) to this shape (______), so you can adjust the camber. for me 80 dollars is better then $200 camber kit or unevent wear
Postby WTF?? » Mon Jul 07, 2003 12:31 pm
Shox.com has them for around $50... ask for Daryl...
But I just got an alignment after i let my springs settle in... the guy said i didnt need any camber adjustment... its fine!! :D
Retired... its been fun Image
WTF??
Postby TadS » Mon Jul 07, 2003 12:36 pm
I know that I asked this 6 months ago (hint). I did a 1.8 drop w/o one and everything is peachy. Tyres are not showing and uneven wear, and the car drives good and strait.
TadS
