SolaraGuy.com • View topic - Spongy feel? can this be fixed with Shocks?
Postby 2001GoldSE » Mon Jul 07, 2003 6:57 am
While driving the Solara i notice that when cornering if you hapen to hit a bump or uneven pavement that the car starts to bounce. Will upgrade with shocks fix this?
2001GoldSE
Postby Jackass-Jeff » Mon Jul 07, 2003 9:01 am
yea stiffer struts will fix this... I don't know if they make stock ride height struts though... but you can check Bilstein and Tokico
1GR-FE ftw!
Jackass-Jeff
Postby DavPak » Mon Jul 07, 2003 10:28 am
xravexboix wrote:yea stiffer struts will fix this... I don't know if they make stock ride height struts though... but you can check Bilstein and Tokico
i think you mean stock ride height springs!
you can use whatever springs you want with aftermarket struts, even the OEM ones.[/b]
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Jackass-Jeff » Mon Jul 07, 2003 11:35 am
oh i thought springs were more for ride height adjustments and the shocks created the stiffer ride depending on the length/stiffness... my bad =x
1GR-FE ftw!
Jackass-Jeff
Postby Yanks0114 » Mon Jul 07, 2003 11:57 am
What you are speaking of is characteristic of the stock suspension. It has its limitations. You'll notice the floating feeling at higher speeds if you go over a bump.
Get aftermarket struts and I'd go for the aftermarket springs also. (Tokico/Eibach)
The ride feels much more stable at high speeds and great improves the cornering
Postby SammySolara » Mon Jul 07, 2003 11:59 am
Yanks0114 wrote: You'll notice the floating feeling at higher speeds if you go over a bump.
"I believe I can fly" - the phrase I utter every time I hit 100+ :angel:
Jen `02 Solara
"Theres no law for how fast you get to the posted speed limit"
<img src="http://free.inkfrog.com/pix/sammysolara/HQ162.jpg">
SammySolara
