SolaraGuy.com • View topic - HELP-please how do I hook up my low and high beam to HID kit
Postby D-money » Sun Mar 08, 2009 6:27 pm
can i splice both factory positive wires together?will that hurt anything? because there is only 1 pos input for the hid kit or is there another way
D-money
Postby D-money » Sun Mar 08, 2009 7:44 pm
anyone there
D-money
Postby 5842solara » Sun Mar 08, 2009 7:54 pm
what kind kit do you have?
good ones are plug and play, even high low.
i dont know if you could put the two postive wires together? i mean you could but then you would have high and low beam same time.
since the kit only has one positive input, you might need a relay kit, cant really tell unless you have pictures or something.
5842solara
Postby D-money » Sun Mar 08, 2009 8:06 pm
it is an ebay plug and play h4
D-money
Postby LEE337 » Sun Mar 08, 2009 8:08 pm
You have a Gen 1, you need H4 bulbs to get high/low beams.
The H4 bulb is a dual bulb. Your reagualr bulb is the HID and your high beam is a halogen.
What kinda bulbs did you get???
Re: HELP-please how do I hook up my low and high beam to HID
Postby LEE337 » Sun Mar 08, 2009 8:10 pm
D-money wrote:can i splice both factory positive wires together?will that hurt anything? because there is only 1 pos input for the hid kit or is there another way
Your ballast should have three wires, i think.
two for your HIDs and one for you halogen high beam.
Postby D-money » Sun Mar 08, 2009 8:17 pm
there are inly two wires to power it.Im pretty sure the low beam power supply turns off when the high beam are on.I need to know if it is safe to run both the low and high lead to the pos on the ballast that is the only way i can see to get both of them to work
D-money
Postby Projex0 » Sun Mar 08, 2009 9:56 pm
post some pictures of the kit
Projex0
Postby D-money » Sun Mar 08, 2009 10:06 pm
i dont have a camera right now i was just wondering in general if any one knew about combining the two pos wires
D-money
Postby Toy1mzfe » Sun Mar 08, 2009 10:12 pm
Hmm not sure what kit you got here. but usually its plug and play.. no splice, no cutting required.
Postby D-money » Sun Mar 08, 2009 10:20 pm
when i plug it it only runs on low beam and turns off when i hit high beams or viceversa if i reverse the connectors here is the link to the ebay item i purchased http://cgi.ebay.com/ebaymotors/_Car-Tru ... 240%3A1318
D-money
Postby Got2XLR8 NYX » Sun Mar 08, 2009 10:29 pm
Not sure if ur aware of this but thats a Kit for H4 Low beam only... that is why when u try to do high beam it turns off... if u want a Highbeam then u shoulda gotten a kit with 2 bulbs (1HID and 1Halogen) or the HID bulb that had a telescopic movement for true HID Highbeam
5Speed 2000 SC V6 @ 4.5PSI
Got2XLR8 NYX
Postby D-money » Sun Mar 08, 2009 10:38 pm
that would be a good reason why it is not doing what i want it to do.since that is the case can i use either high or low output to power the unit .also can i modify it so both out puts trigger the relay or will it damage something if i touch the two power wires together i dont care if it gets brighter or not cause these things are freakin bright
D-money
Postby Mole » Sun Mar 08, 2009 11:03 pm
putting 2 power leads together won't make your lights brighter.
the kit you have does not have a high beam.
the high beam power is no longer used with your kit installed.
Postby D-money » Sun Mar 08, 2009 11:08 pm
im not wanting to make them brighter i just want them to work weither or not my highs are on
D-money
