SolaraGuy.com • View topic - How to adjust HID pointed down?
Postby BlKSo|aRa » Mon Mar 09, 2009 6:41 pm
after installing my HID the light just go everywhere, and i dont want to blind any1 on the road. so how do i adjust it so that it pointed down at the road. thanks. gen 1.5 by the way
BlKSo|aRa
Postby TLMNICK » Mon Mar 09, 2009 6:53 pm
if you look at the back of the headlight housing....you'll see adjustment screws. There are two on each headlight....one to adjust side-to-side and the other one is for up-and-down.
you'll obviously want to adjust the up-and-down one. You're lucky that you have a gen 1.5....those housings are way better for HIDs than the gen1's are. Thats why I did a retrofit....the gen1 headlights are complete garbage if you wanna put HIDs in them.
TLMNICK
Postby Ilovemylara » Mon Mar 09, 2009 6:59 pm
theres a screw on the inside of the headlight between the two bulb housings get a #2 phillips screwdriver and turn it, clockwise to go up, and counterclockwise to go down :)
Postby BlKSo|aRa » Mon Mar 09, 2009 7:11 pm
^^ u mean the 1 look like a cap? between the high beam n low beam?
BlKSo|aRa
Postby ThatVietGuy » Mon Mar 09, 2009 7:12 pm
Ilovemylara wrote:theres a screw on the inside of the headlight between the two bulb housings get a #2 phillips screwdriver and turn it, clockwise to go up, and counterclockwise to go down :)
Correct, but 8mm socket, not a screwdriver.
ThatVietGuy
Postby ThatVietGuy » Mon Mar 09, 2009 7:15 pm
BlKSo|aRa wrote:^^ u mean the 1 look like a cap? between the high beam n low beam?
Yes, it's gray and near the top.
ThatVietGuy
