SolaraGuy.com • View topic - Stock suspension
Stock suspension
Stock suspension
Postby solara1989 » Tue Mar 10, 2009 11:08 am
Quick question, can i install a rear sway bar with stock suspension, or should be better to drop the car n then install the rsb?
And if i do istall the rsb with stock suspension would there be any contradiction(suspension too soft)? Thanks Everybody.
2000 Solara SLE V6 Diamond White
solara1989
Postby lilm » Tue Mar 10, 2009 11:11 am
yes you can install it
lilm
Postby Midias » Tue Mar 10, 2009 11:15 am
Yes and you should best handling bang for the buck.
Postby Ilovemylara » Tue Mar 10, 2009 12:05 pm
Just dont forget to lube up those bushings, I used silicone grease. no more *squeeaak*
Postby Midias » Tue Mar 10, 2009 12:30 pm
I found Teflon paste works the best then lithium lube then silicon and lastly pertro based lube.
Postby ASG14 » Tue Mar 10, 2009 1:02 pm
I used teflon tape. Don;t use normal grease, it wears off and squeeks.
ASG14
Postby LEE337 » Tue Mar 10, 2009 3:47 pm
Midias wrote:I found Teflon paste works the best then lithium lube then silicon and lastly pertro based lube.
X2
Postby yaddadaimsayin » Tue Mar 10, 2009 4:51 pm
+1 for KY
Postby Ilovemylara » Tue Mar 10, 2009 5:37 pm
^^David, Im sure you have a vast supply of KY :wink: j/k
Postby SleeperSolara » Tue Mar 10, 2009 8:09 pm
ASG14 wrote:I used teflon tape. Don;t use normal grease, it wears off and squeeks.
Yeah i used teflon tape and the lithium grease.
Postby Toy1mzfe » Tue Mar 10, 2009 9:35 pm
I Still havent got the rsb.
GO get it, heard its like "day and night" big ass difference. JUst lubb like crazy or it will be squeaking like a cheap hotel bed.
Postby ToyoSolV6 » Tue Mar 10, 2009 10:07 pm
^hahahaah yeah exactly like that!
