SolaraGuy.com • View topic - eBay Clutch - Need opinions
Which should I go with?
F1 Racing, Stage 3 Clutch
1
17%
Phoenix Friction OE Replacement Clutch Kit
0
No votes
None of these
5
83%
Total votes : 6
Postby mazen222 » Thu Mar 12, 2009 9:24 am
My clutch is almost dead now... its slipping alot. So I am thinking of going with eBay instead of the $700 toyota wants for an OEM clutch.
I found these two, one of them is OEM specs and the other is a Stage 3 clutch. Im debating if i should go with the stage 3 or not. My car is stock, I like to race sometimes, but its on occasions. And I also like the smooth shifting of the OEM clutch.
Both are almost the same price, so I am tempted to go with the Stage 3 clutch, but im afraid the quality will suck and the shifting will be very abrupt...
What do you think?
F1 RACING STAGE 3 CLUTCH
http://cgi.ebay.ca/F1-RACING-STAGE-3-CLUTCH-99-02-TOYOTA-SOLARA-3-0L-6CYL_W0QQitemZ350109826190QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?_trksid=p3286.m20.l1116
http://cgi.ebay.ca/1999-99-Toyota-Solara-6-Cyl-3-0-L-New-Clutch-Kit_W0QQitemZ140305168544QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?_trksid=p3286.m20.l1116
1999, 5 Speed V6
mazen222
Postby Eye8Pussies » Thu Mar 12, 2009 9:40 am
lol stage 3 clutch on a stock car. long story short don't do it. both for comfort's sake and getting laughed at by other ppl.
I have a stage3 clutch and it sucks in traffic. but I'm boosted, etc etc
Postby Mr_Krispy1183 » Thu Mar 12, 2009 9:46 am
^Wise words from a wiser Camry sage.
Postby Midias » Thu Mar 12, 2009 10:08 am
I vote neither stage 3 on a stock car that must be a joke. I would get THIS
Or if you just want a clutch THIS
Postby mazen222 » Thu Mar 12, 2009 10:13 am
Midias wrote:I vote neither stage 3 on a stock car that must be a joke. I would get THIS
weird... that second one didnt come up in my search... its even cheaper than the phoenix one.
Alright case cklosed, im going with the exedy
1999, 5 Speed V6
mazen222
Postby jetbtkng » Thu Mar 12, 2009 10:36 am
Item Description | Vehicle Application | Shipping & Handling | Payment Details | Return Policy | About Us
About this item
ACT is a leading high performance clutch and flywheel manufacturer for the Sport Compact, Domestic and Truck markets. For over 11 years, ACT has focused on quality, service and performance to deliver an unparalleled product. ACT heavy-duty pressure plate is manufactured from new unit, not rebuilt from worn out part. Proper geometry is maintained for long clutch life through a reliable single diaphragm design. F1 Racing street disc is constructed with heavy-duty material and reduced marcel for faster shift action to compliment ACT pressure plate. Spring center construction properly dampens torsional vibrations for quieter operation and center hub springs help lessen the drive train shock and impact. It also increases heat tolerance which helps prevent warping of mating surfaces. The clutch requires 500 mile break-in periods. Actual item may differ from the picture below.
The following ACT clutch kit includes:
ACT heavy-duty Pressure Plate (clamp load increase: 32%)
F1 Racing Street Disc (236mm, 21 splines)
Release Bearing
Alignment Tool
Clamp Load Increase: 32% / Torque Capacity: 390 ft/lbs
Retail Price: $ 567
TC4-R0D-SS #16
Buy from the right seller! Gripforce is the largest ACT distributor on eBay! We guarantee the lowest price on all genuine ACT products on eBay.
Back to Top :drinking:
Vehicle Application
1999 - 2002 Toyota Solara (3.0L V6)
View larger picture
price: US $305.00 Buy It Now >
(approximately C $390.67)
Ships to: Worldwide
Item location: Brea, CA, United States
Quantity: More than 10 available
History: Purchases
You can also:
Bid with Bid Assistant
Get alerts via Instant Messaging
Postby mazen222 » Thu Mar 12, 2009 10:45 am
1999, 5 Speed V6
mazen222
Postby Midias » Thu Mar 12, 2009 10:51 am
^ yes a quick look on exedy's completely public website that anyone could look at if they wanted information any time of day and very quickly and easily using a search on a part number reveals that part number 16062 fits all of these vehicles.
16062 1993 - 2001 CAMRY BASE V6; 3.0L; Non-Turbo; Gas(ALL; 1MZFE)
16062 1997 - 1997 CAMRY CE V6; 3.0L; Non-Turbo; Gas(1MZFE)
16062 1992 - 1992 CAMRY DLX V6; 3.0L; Non-Turbo; Gas(3VZFE)
16062 1993 - 1993 CAMRY DX V6; 3.0L; Non-Turbo; Gas(3VZFE)
16062 1992 - 1997 CAMRY LE V6; 3.0L; Non-Turbo; Gas(3VZFE; 1MZFE)
16062 1992 - 1994 CAMRY SE V6; 3.0L; Non-Turbo; Gas(3VZFE; 1MZFE)
16062 1992 - 1997 CAMRY XLE V6; 3.0L; Non-Turbo; Gas(3VZFE; 1MZFE)
16062 1991 - 1995 MR2 BASE L4; 2.0L; Turbo; Gas(3SGTE)
16062 1999 - 2002 SOLARA BASE V6; 3.0L; Non-Turbo; Gas(1MZFE)
Postby 1gSE » Thu Mar 12, 2009 11:17 am
crap, you cant go wrong with that price!
Solara-M62 @ 5.5psi
1gSE
Postby akora12 » Thu Mar 12, 2009 11:27 am
I'd go with exedy for a stock clutch. If you still want some extra hold, check out the Clutch Masters stage 2 kit. I have it and it shifts like stock, but it's not exactly cheap.
Postby mazen222 » Thu Mar 12, 2009 11:27 am
ok i just bought the Exedy without the flyweel... I will use my original flyweel and resurface it
Thanks everyone!
1999, 5 Speed V6
mazen222
Postby Midias » Thu Mar 12, 2009 11:37 am
^ sounds good exedy makes a good clutch but I would have gone for the light weight flywheel. Hell if my clutch ever goes I will get that combo but 165,000 miles and it is still going strong.
Postby hskrsolara » Thu Mar 12, 2009 7:11 pm
I would go with the exedy for a stock application.
If you plan to upgrade, SPEC makes the best clutches out there. They're worth it.
hskrsolara
Postby DatSRBoi » Thu Mar 12, 2009 8:31 pm
FYI- There has been known frauds where people get pressure plate and put some good paint coating on them and rename them a name brand. I personally have not brought any on ebay and never will unless its something bad ass and i know it can not be flaked. I have personally seen people on other forums with this issue. Some are also getting knock off name brand plate that looks EXACTLY like the real thing but after a few hard runs the pressure plate have crack in half.
FYI.
Postby hskrsolara » Thu Mar 12, 2009 9:56 pm
buy from horsepowerfreaks.com. they're good people and sell authentic goods.
hskrsolara
Users browsing this forum: No registered users and 79 guests
