SolaraGuy.com • View topic - HELP!!! HID fogs
HELP!!! HID fogs
HELP!!! HID fogs
Postby D-money » Tue Mar 24, 2009 1:09 pm
im having a problem getting my hid kit to work with my fogs.I hook up the kit it is a plug and play and i turn it on and nothing when i hook it up to my reg headlights it works fine so i know call components are working.is there less voltage output from the fogs? Do I have to install a relay? has anyone had this problem?
D-money
Postby Ruski » Tue Mar 24, 2009 1:25 pm
How are you testing your Fogs with the Use of your Headlights , The Gen1 have H4 for headlights and 9006 for Fogs.
What kit do you have ?
Postby D-money » Tue Mar 24, 2009 1:27 pm
I just use the power wire from the extra h4 bulbs i have
D-money
Postby scdsolara619 » Tue Mar 24, 2009 2:54 pm
Ruski wrote:How are you testing your Fogs with the Use of your Headlights , The Gen1 have H4 for headlights and 9006 for Fogs.
I could be mistaken, but according to Sylvania.com the 1999-2001 use 9003/HB2 for low/high beam headlight and 9006 for fog, and 2002-2003 use 9006 low beam, 9005 high beam, and 9006 for fog lights. Make sure you have the right bulbs.
02 SE V6 (S/C) AT
scdsolara619
Postby mazen222 » Tue Mar 24, 2009 2:56 pm
make sure that u plug the wire into the ballast correctly. The wire will fit in both ways ( plus to minus, and plus to plus). I had the same issue with one side when i installed my headlights
gl
1999, 5 Speed V6
mazen222
Postby D-money » Tue Mar 24, 2009 4:19 pm
I have tried that and still have a problem and the bulbs fit perfectley any other ideas
D-money
Postby ClassySolaraGuy » Tue Mar 24, 2009 5:42 pm
Check fog fuse/relay? Better grounding possibly.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby D-money » Tue Mar 24, 2009 5:59 pm
when i put the reg bulb in everything works so i dont think that is the problem
D-money
