SolaraGuy.com • View topic - How much bump stop?
How much bump stop?
How much bump stop?
Postby nemoxfishy » Fri Mar 27, 2009 2:16 pm
Quick question, quick answer please, as im sitting at the computer holding an exacto knife with my car jacked up outside WAITING FOR AN ANSWER :lol:
How much do you cut the bump stop on the rears?
I have Tein springs but I don't have the instructions!! Tein's site doesn't have it for the Solara either. HELP!
I searched but can only find results for the fronts, which is about 1" or half of its length. HOW ABOUT THE REARS?
Thanks!!
nemoxfishy
Postby CASTRO » Fri Mar 27, 2009 2:22 pm
i believe it was about less than half so 1/3 should be safe.
CASTRO
Postby nemoxfishy » Fri Mar 27, 2009 2:26 pm
THX~!
nemoxfishy
Postby nemoxfishy » Fri Mar 27, 2009 2:27 pm
Anyone can verify? Or else i'm gonna head out and start cuttin!!
nemoxfishy
Postby akora12 » Fri Mar 27, 2009 2:38 pm
This may be too late, but here's a photo that's on the forum somewhere.
That's where I cut mine.
Postby nemoxfishy » Fri Mar 27, 2009 2:40 pm
^^LOL I come back in to check every now and then =]
I believe that picture is only for the front bump stops?
nemoxfishy
Postby akora12 » Fri Mar 27, 2009 2:45 pm
Dunno, I cut all of them the same with no problems. Same for all of my hondas as well.
Postby ArizonaEagle07 » Fri Mar 27, 2009 3:09 pm
May I ask what is the purpose of cutting the bump stop?
RIP: 2000 Toyota Solara SLE
ArizonaEagle07
Postby funboy102 » Fri Mar 27, 2009 4:03 pm
ArizonaEagle07 wrote:May I ask what is the purpose of cutting the bump stop?
+1, what is the reason? I didn't cut mine and it's all good.
funboy102
Postby nemoxfishy » Fri Mar 27, 2009 4:06 pm
Thx guys~!
the job is done!!
^Bump stops prevent your shocks from banging onto the chassis when you bottom out. However, with shorter aftermarket springs we will bottom out early if we don't cut the bump stops.
nemoxfishy
Postby SleeperSolara » Fri Mar 27, 2009 9:39 pm
I think i had cut my bump stops in half and used the top half since it had a bigger base.
Postby LEE337 » Sat Mar 28, 2009 6:43 am
I cut my bump stops in half as well when I put my Teins in.
