SolaraGuy.com • View topic - Injen Intake prob.
Injen Intake prob.
Injen Intake prob.
Postby hnda8r » Thu Jul 10, 2003 5:26 am
I installed an Injen Intake in my 2000 Solara last night and the check engine light comes on. Can anyone help me? I followed the instructions. If not i"ll go :crazyeyes:
In search for my next Supercharged Solara!!!
hnda8r
Postby Akfahad » Thu Jul 10, 2003 5:44 am
give it some time. the engine has to adjust, it takes a couple of key turns and couple of driving cycles before it goes off, but it will eventually. One of my friends who works on Audi's, he told me they take like 40 key turns before the engine light goes off, but the Solara isn't nearly that much.
Postby shidosha01 » Thu Jul 10, 2003 5:54 am
Did you disconnect the battery? You should do that to reset the ECU.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby hnda8r » Thu Jul 10, 2003 9:08 am
shidosha01 wrote:Did you disconnect the battery? You should do that to reset the ECU.
Yes I disconnected the battery for about 15min, then i started my car and let it run for awhile (about 10min), and it still comes on. :o ?????????
hnda8r
Postby Yanks0114 » Thu Jul 10, 2003 9:20 am
recheck all your hoses and connections, sounds like you have an air leak
Postby ronin » Thu Jul 10, 2003 10:25 am
when i put it on my car, i started by disconnecting the battery and let it sit for some 40 mins while i put the intake on. made sure all the hoses were on tight and then pluged it back in. never once did i get the check engine light. i did get it when i put the stock air box back on though. lol
ronin
