SolaraGuy.com • View topic - Big and affordable rotors
Postby rewmomi » Mon Apr 13, 2009 8:46 am
I wanted to get a set of 4 cross drilled slotted rotors but i did not want to spend more than 250 on then and i want it to be big enough to fill the space in between an 18 in rim.
rewmomi
Postby akora12 » Mon Apr 13, 2009 8:51 am
Most big brake kits are over $1,500...
Postby sarki » Mon Apr 13, 2009 9:18 pm
I have a friend that works at Undercar in Pasadena. He can get slotted and drilled rotors for pretty cheap. The quality is really good and it looks sick. But before i throw out a price, I'll call him and get some prices and specs.
Who wants to buy it?
sarki
Postby ThatVietGuy » Mon Apr 13, 2009 11:11 pm
How can you possibly expect just rotors to fill space between a rim?
Like Akora said, if you want to fill the space between the rotor/caliper, you need a BBK.
ThatVietGuy
Postby funboy102 » Mon Apr 13, 2009 11:15 pm
akora12 wrote:Most big brake kits are over $1,500...
Yup, BBK are at least $1,000, so good luck finding one for a lot less than that.
As for slotted/drilled rotors under $250, it can be done, stock size.
Front's
http://store.r1concepts.com/Items/Item. ... 0-%20Front
And Rear's
http://store.r1concepts.com/Items/Item. ... 20-%20Rear
They doing good on my car.
funboy102
Postby rewmomi » Tue Apr 14, 2009 6:25 am
Someone on here had the supra ones on the solara and the rotor was much bigger than the sstock size
rewmomi
Postby akora12 » Tue Apr 14, 2009 6:52 am
The ericsol kit costs about $250 in itself, then you have to buy the supra rotors.
Postby trdkamuri51o » Tue Apr 14, 2009 7:34 am
Akora that's a bit high at most your going to pay 200 foe the kit
trdkamuri51o
Postby CamryOnBronze » Tue Apr 14, 2009 8:19 am
^ with demand and the kit being hard to find, it would not be surprising at all to see the kit sell for $250 IMO...
Postby sarki » Tue Apr 14, 2009 9:32 pm
I spoke with my friend at Undercar and here is what he can get and the prices he gave me.
Royalty Rotors $120 pr (stock size-cross drilled and slotted)
Power slots $160 pr (slotted)
Stop Tech BBK $1,600 ( 13" Slotted Rotors, Pads, Calipers, and Bracket)
These are out the door prices. I dont know if this is a good deal but i hope it helps.
sarki
Postby rewmomi » Tue Apr 14, 2009 9:37 pm
thanks for all ur help guys i probably will just save up for a big brake kit instead
rewmomi
Postby trd4life » Wed Apr 15, 2009 5:00 am
I'm going to have a Eric Sol big brake kit for sale in a couple days, with supra rotors. PM me
Postby mazen222 » Wed Apr 15, 2009 5:42 am
in order to have bigger rotors you will need a different caliper... so taking your budget into consideration, forget about it :P
1999, 5 Speed V6
mazen222
Postby Robert » Wed Apr 15, 2009 6:46 am
Front's
And Rear's
I ordered From that vendor before for cross drilled rotors on my sisters Mitsu Gallant, They ended up Rusting after about 3 months
Could have been a bad batch, but it was the same vendor just FYI
Robert
Postby akora12 » Wed Apr 15, 2009 6:52 am
^Did you get the E-line or premiums? I know the G35 forums were pissed about their premiums rusting.
Users browsing this forum: Majestic-12 [Bot] and 44 guests
