SolaraGuy.com • View topic - gauge pod
gauge pod
gauge pod
Postby 5842solara » Wed Apr 15, 2009 2:44 am
hey, do you guys know if the a-pillar on a 99-00 camry same as 00 solara?
I looked and found this gauge pod but wondering if would fit.
http://performanceparts.com/part.php?partID=165610
thanks
5842solara
Postby akora12 » Wed Apr 15, 2009 5:17 am
They a-pillars aren't the same, but you can make the pod fit with a little work. It probably won't be perfect, but it will get you by.
Postby 5842solara » Wed Apr 15, 2009 8:55 am
akora12 wrote:They a-pillars aren't the same, but you can make the pod fit with a little work. It probably won't be perfect, but it will get you by.
do you by chance know which year is the same.. I know they say gen 4 is the same as gen 1 solaras. are the a-pillars the same for the two cars as well?
5842solara
Postby akora12 » Wed Apr 15, 2009 9:46 am
No, they aren't the same. While the gen 4 camry (97-01) shares the same chassis with the gen 1-1.5 solara (99-03), the interiors aren't identical. The a-pillars on the solara are model-specific.
Postby indiglosolara » Wed Apr 15, 2009 5:46 pm
I used a camry Gen 4 Dual pod when I had one installed in my solara. The A-pillar is really similar or close enough that it fits pretty nice..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby 5842solara » Thu Apr 16, 2009 1:46 am
indiglosolara wrote:I used a camry Gen 4 Dual pod when I had one installed in my solara. The A-pillar is really similar or close enough that it fits pretty nice..
do you have pics by chance?
probably try this setup if you say that they are similar..
5842solara
Postby indiglosolara » Thu Apr 16, 2009 9:12 am
sorry... I parted my car a long time ago... Can't remember where I had them...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby facevedo17 » Thu Apr 16, 2009 9:23 pm
Im using gen 4 camry on mines fits good not perfect
facevedo17
Postby 5842solara » Thu Apr 16, 2009 11:52 pm
facevedo17 wrote:Im using gen 4 camry on mines fits good not perfect
do you have a picture? is it dual?
5842solara
