SolaraGuy.com • View topic - new RSB links?
how many people had to replace their RSB links when they added the TRD RSB
Poll ended at Fri May 01, 2009 6:21 pm
YES
2
22%
NO
7
78%
Total votes : 9
new RSB links?
new RSB links?
Postby D-money » Tue Apr 21, 2009 6:21 pm
i am going to put the TRD RSB on and i have read alot about it but i want to be prepaired there might be a poll for this already but i couldnt find it. what do you think about these http://cgi.ebay.com/ebaymotors/2-REAR-S ... ccessories
D-money
Postby D-money » Tue Apr 21, 2009 6:44 pm
any body else?
D-money
Postby '_' » Tue Apr 21, 2009 7:51 pm
I didn't have to when I installed mine. Curious to see what others will say though..
'_'
Postby JamesT » Tue Apr 21, 2009 7:54 pm
I did but on only because mine were really old and all rusted up.
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby TMMK Toy » Tue Apr 21, 2009 8:01 pm
That's a steal. I didnt have to replace mine when I did mine, but it's all about luck and if yours have seen much road salt or not.
TMMK Toy
Postby D-money » Tue Apr 21, 2009 8:47 pm
i just went out and took a look and i see no rust any where and the car has been here in sunny socal all its life is the rust the usual reason for replacement?
D-money
Postby JamesT » Tue Apr 21, 2009 9:03 pm
D-money wrote: is the rust the usual reason for replacement?
Unless the rubber seal is broken and there is grease leaking out, rust is usually why people need to replace them.
BespokeAutoInterior
JamesT
Postby SleeperSolara » Wed Apr 22, 2009 3:10 pm
Sometimes you could run into the problem of strippin' the hex stud.
Postby akora12 » Wed Apr 22, 2009 3:29 pm
I don't have a TRD RSB, but I had to replace my rear links twice for both of my suspension installs. The second set was only a year old and I still had to cut them off. Save yourself the hassle and don't buy OEM if you need ot replace them.
Postby TadS » Wed Apr 22, 2009 7:06 pm
It's a good idea to at least know where a set is just in case. I would say when I was wrenching I broke probably 50% of them when I was replacing struts.
TadS
Postby unbalancedwood » Wed Apr 22, 2009 7:34 pm
I had to replace mine cause the threads/allen wrench hole was stripped. Think I paid around thirty/five for one, got them at AdvancedAuto but they were thicker then your post...but i would get them just in case or in the case that yours are damaged...
unbalancedwood
