SolaraGuy.com • View topic - port and polishing intake manifold and head
Postby x99suplarax » Wed Apr 29, 2009 3:46 am
i have searched.. but no find.. sry if it isnt in the right forum... didnt know wat it would be in.. but has anyone done it yet, port and polish? im thinkin about getting it done mid MAY with my bonus.. i have a friend that know someone that does it cheap with good quality.. feed back please?
x99suplarax
Postby x99suplarax » Wed Apr 29, 2009 2:17 pm
No replies
x99suplarax
Postby SleeperSolara » Wed Apr 29, 2009 2:53 pm
I think it would help alot wit the flow of air.
Postby gnegroni » Wed Apr 29, 2009 3:03 pm
Endyn (http://www.theoldone.com) does job for Hondas mainly but their experience and results are just awesome. However, they don't polish since it increases the possibility of fuel droplets sticking into port walls (possible detonation chance increase).
If you are going to have ported heads, have somebody with knowledge on YOUR particular product. If 2AZ-FE engine is under your hood, any shop that has ported scion tC heads will do. If you have the 1MZ, I suggest Gabe.
gnegroni
Postby x99suplarax » Wed Apr 29, 2009 3:09 pm
Who is gabe again?
x99suplarax
Postby x99suplarax » Wed Apr 29, 2009 3:16 pm
So is the polish not a good thing?
x99suplarax
Postby panic » Wed Apr 29, 2009 4:15 pm
Someone who has done perhaps 50 sets of heads for this specific engine, using a flow bench, then dyno-tested before trying the car out in 1/4 mile etc?
If not the results can be anything from "feels slightly better", to "feels different, but I'm not sure if it's faster" (very common) to "well, that was a whole lot of money wasted", and finally, the ever popular loud noises and "where's all that oil coming from?".
Making it faster on top end is easy: make all the holes bigger. Of course, everything below 4,000 is toast along with mileage.
This is a very low mileage engine in perfect condition, with less than 5% leak-down and 5% variation between cylinders, isn't it?
panic
Postby trd4life » Wed Apr 29, 2009 4:27 pm
Both sets of 1mz heads i have run that were ported and polished were done by Carlos at Arietta Motorsports (shop now closed i believe). MY last 3mz/1mz hybrid had a set of ported and polished heads and lower intake. Def. a huge power gain when tuned.
I have a new guy doing porting for me , PM me for more info.
Thanks,
gabe
Postby panic » Wed Apr 29, 2009 4:30 pm
And that's how you find some - a guy who'se done this won't trust someone who can't produce good results.
panic
Postby gnegroni » Wed Apr 29, 2009 8:05 pm
Gabe and panic, thanks for joining in! Can't give the guy better input than what you've given him.
gnegroni
Postby trd4life » Thu Apr 30, 2009 4:38 am
you'll have to add a fuel controller to add fuel after the porting to compensate for the increased airflow.
