SolaraGuy.com • View topic - OBX Headers Feedback
Postby anttarz » Fri May 08, 2009 7:08 am
I am looking to purchase a set of performance headers for V6 (1MZ-FE - California Emissions) The bung ripped off while removing the A/F(O2) sensor from S1B1, now I have a 2.5" hole.
I have a few questions abouts about the OBX headers:
-Will I be able to pass emissions (no check engine light)?
-Any fitment issues?
**Im pretty sure there are no fitment issues from what I've read.
-Are the gaskets, if included any good or should I got OEM?
-Any other feedback?
Thanks!
anttarz
Postby SleeperSolara » Fri May 08, 2009 9:28 am
Yeah you should be fine i think, as long as you hve your O2 sensors, and catalytic converter.
The OBX setup doesn't come wit a catalytic converter, it comes wit a resonator.
The y-pipe hangs a bit low though.
OBX headers
Postby cartang » Fri May 08, 2009 9:48 am
I am Tampa FL I am going to buy these headers too. Are they made for Non-california specs .? I am in Florida
My Camry 1999 SC 5 speed ( with Greddy cat back ) :D thanks for the answers
cartang
Postby yoboyandre » Fri May 08, 2009 9:50 am
I was reading some reviews on OBX headers and alot of people say that its not an exact fit and alot of negative reviews on diffrent websites and diffrent cars, i dont know if its the same on our solara's or if they have improved. Just lookin' out.
yoboyandre
Re: OBX Headers Feedback
Postby Midias » Fri May 08, 2009 9:55 am
No not as they come from the OBX factory. You will get a code for no cat and will need to cut off the resonator and add one. Or install an o2 sim.
None known
Get OEM for the area between the head and the manifold.
Postby Eye8Pussies » Fri May 08, 2009 12:54 pm
^ exactly what midias said
fits great, and also comes with gaskets, but they are all fiber gaskets. I replaced my manifold gaskets with oem metal ones htough
Postby TMMK Toy » Fri May 08, 2009 4:07 pm
The negative fitment issues you prob. read bout were the older style headers. They now employ the JPP design so fitment is much better and like the others said, go with the oem metal gaskets.
TMMK Toy
Postby jetbtkng » Fri May 08, 2009 4:15 pm
i have obx on my 02 no fitment probs but if they do a visual insepction u might have problems............... :drinking:
Postby anttarz » Wed May 13, 2009 12:11 pm
Any suggestions on an O2 sim?
Any suggestions on a cat to add?
If I were to use the OBX headers without adding a cat (use O2 sim) how much louder will the car be at start up and idle?
anttarz
Postby Midias » Wed May 13, 2009 12:40 pm
anttarz wrote:Any suggestions on an O2 sim?
O2 sim I hear underdog racing is good.
For a cat thunderbolt makes a nice cheap OBD2 stainless cat.
Magnaflow makes a better filtering but more expensive version. I prefer metal core vs ceramic for better flow but cost goes way up.
Sound would probably not change between the 2 because the OBX headers use a resonator instead of a cat which will remove rasp and make the exhaust sound deeper and a little quieter.
Postby GzNutz » Wed May 13, 2009 2:18 pm
URD O2 sim FTW. Had one for about 2.5k and no more "your o2 sensors are missing" CELs. Very simple install.
OBX headers
Postby cartang » Thu May 14, 2009 11:28 am
Any reliable web to buy them ?'
Are there 2 kinds of OBX headers ? ( California , and non California specs) or its just the same .
I got my camry in FL . Thanks for the answers
cartang
Re: OBX headers
Postby Midias » Thu May 14, 2009 11:33 am
cartang wrote:Any reliable web to buy them ?'
No they are the same and will fit both
Postby TMMK Toy » Thu May 14, 2009 10:34 pm
URD sells the 02 simulator and def. go with it. My friend wired mine up for me when we installed a highflow y pipe with high flow cat and that was at maybe 70k or so. I just turned 100k and no CELs.
TMMK Toy
OBX
Postby cartang » Fri May 15, 2009 5:15 am
Any good reliable place to buy the OBX headers Thanks for the answers
cartang
