SolaraGuy.com • View topic - question about wheel spacers
Postby D-money » Mon May 11, 2009 5:15 pm
im thinking about widening the stance of my lara the suspention is stock other then the RSB i need to know what is the best size spacers to use with out having any issues with my stock 16 alloys and does any body know a place to get them cheap?
D-money
Postby Mr_Krispy1183 » Mon May 11, 2009 5:51 pm
Postby D-money » Mon May 11, 2009 9:27 pm
does anyone know if 8mm spacers will fit on stock lug bolts
D-money
Postby ThatVietGuy » Mon May 11, 2009 9:30 pm
What do you mean by fit.
Will the spacer go over the bolts or will you'll be able to thread the lug?
Answer should be yes for either.
ThatVietGuy
Postby D-money » Mon May 11, 2009 10:23 pm
threading the lug thanks
D-money
Postby Midias » Tue May 12, 2009 8:09 am
D-money wrote:does anyone know if 8mm spacers will fit on stock lug bolts
For 5mm and up you need longer studs. 5mm spacers and stock lugs will hold the tire on but without longer studs my car had a weird shake.
Postby Akfahad » Tue May 12, 2009 8:12 am
you'll be fine with using your stock studs w/ a 5mm; anything over, you'll need to swap...like Midias said.
Postby Midias » Tue May 12, 2009 8:14 am
Akfahad wrote:you'll be fine with using your stock studs w/ a 5mm; anything over, you'll need to swap...like Midias said.
With 5mm spacers and stock studs I had a weird shake that was fixed with the longer studs provided. But it should still be ok.
Postby akora12 » Tue May 12, 2009 8:16 am
I could just get the minimum amount of turns on the lugs with a 5mm spacer, but I still didn't feel safe driving like that. Personally, I would use longer studs with any spacer above 3mm.
Postby D-money » Tue May 12, 2009 10:58 am
where those with stock rims because i noticed none of you have them
D-money
Postby Midias » Tue May 12, 2009 11:05 am
D-money wrote:where those with stock rims because i noticed none of you have them
They were with stock gen 2 rims
Postby '_' » Tue May 12, 2009 11:06 am
I have some 5mm spacers if you're interested..
'_'
Postby Midias » Tue May 12, 2009 11:11 am
I have some extra used ichiba spacers but no studs I think they go for 70 new with studs you can have them for 25+ shipping prob about 5 bucks.
Postby panic » Tue May 12, 2009 11:30 am
panic
Postby D-money » Tue May 12, 2009 11:31 am
if i remove the washer on the stock lug nuts it gives me 2mm more to work with so that is a total of 14mm thread length so if i put 8mm spacers that leaves me 6mm of thread left do you guys think that will be enough.what size are the ichaba spacers midas and how many of the 5mm spacers do you have guy
D-money
