SolaraGuy.com • View topic - FOG LIGHT BULB REPLACEMENT *HELP*
Postby ampreston85 » Sat May 30, 2009 4:03 pm
I'm having some nice Nokya Fog Bulbs put in... yellow... anyway, tried searching for how to replace the bulb. found nothing. So how easy/hard is it? do i have to remove bumper cover????? or just some bolts/screws? an explanation would be great
ampreston85
Postby ThatVietGuy » Sat May 30, 2009 4:11 pm
You can unbolt the fender liner and pull it away to stick you arm into the area where the bulbs are.
It also helps if you turn the wheel to full lock to make it easier to pull the liner.
ThatVietGuy
Postby TLMNICK » Sat May 30, 2009 7:03 pm
The easiest way to do it it to jack the car up a bit (if you're lowered), and unbolt the splash shields from underneath. You can either swap the bulbs out right from there, or you can unbolt them completely and take them right out.
It's not a terribly difficult task, just time consuming.
TLMNICK
Postby ampreston85 » Sat May 30, 2009 8:24 pm
thnx guys.... just got my fogs in. Looks nice. Will take pics at dusk to show the new look
ampreston85
