SolaraGuy.com • View topic - Headlight and Fog Light Bulbs
Postby robbievelasco » Tue Jun 09, 2009 8:21 am
I want to purchase new bulbs for my headlights and fog lights but don't want to go HID(putting my money into suspension right now). Anyway, I tried looking for some and there are so many different choices between h1, h2, h4, etc. Which ones should I get?? If it helps I also want purple for the headlights and yellow for the fogs. Thanks for your help!
Side blurp: After I get the suspension installed I'm going with either the Kaminari lip kit or the Solara VIP body kit. Any comments on any of those two kits. I always see the Kaminari kit but I've never seen the VIP kit anywhere.
Thanks again!
robbievelasco
Postby ASG14 » Tue Jun 09, 2009 8:24 am
1: Purple headlights are retarded, period. You can't argue that, and light output sucks. yYou want a white to very light blue tinge.
2: h1, h2, h4, are different bulbs. You can't put in a different bulb then stock unless you want to change wires and headlight sockets.
ASG14
Postby Ilovemylara » Tue Jun 09, 2009 8:33 am
^what he said. Also, just go with kaminari, it will cost more to get the vip body kit to fit. TRUST ME, they Never come ready-to-install, the bumpers will have to be trimmed and painted, and because there isnt really much of a grill on the front bumper, this kit will probably affect your engines cooling system. plus its made of fiberglass, so it will crack after about a year due to temperature changes and stress.
Kaminari FTW
Postby Pogs » Tue Jun 09, 2009 8:53 am
If you want purple get purple. You know what you want and only you. ASG has a point with the output and such but get what you want and dont let other people tell you how it should be. I thought a member named ASTRO has the vip kit. If not him someone has it. It looks really good but it took a lot of fabrication and money to get it like that. The kaminari kit has great looks and pretty much garenteed to fit. Do what you think youll like best. If you dont like what you do then you will end up changing it.
Search and Win
Pogs
Postby yaddadaimsayin » Tue Jun 09, 2009 9:09 am
yeah those are bulb sizes. I believe the gen1 is h4? gen2 is h11.. yadda yadda. not much of a choice for you there. You can get cheap HIDs too (at around 12000k they'll be purple), but if all you want is a different color bulb, i guess you can do that too.
Postby Ilovemylara » Tue Jun 09, 2009 9:20 am
What astro has is the "black widow" or r33 kit heres his cardomain: http://www.cardomain.com/id/astro73
This is the vip kit the op was talking about
Postby yaddadaimsayin » Tue Jun 09, 2009 9:38 am
wow! both are hella clean! big ups to Astro for having a cleanass ride!
Postby robbievelasco » Wed Jun 10, 2009 9:51 am
Thanks for all the advice! I'm going to purchase some H4 bulbs and then pick up the Kaminari lip kit! I'll post pics once those two things are done. Then I'm off to buy Tein Springs and Tokico blues :)
robbievelasco
Postby Ilovemylara » Wed Jun 10, 2009 9:59 am
good luck man!
Postby NightRider » Wed Jun 10, 2009 10:56 am
Don't want to do HID's ?
And you can't go wrong w/ the kam kit. You will be happy!
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Mr_Chunkz » Wed Jun 10, 2009 11:32 am
robbievelasco wrote:Thanks for all the advice! I'm going to purchase some H4 bulbs and then pick up the Kaminari lip kit! I'll post pics once those two things are done. Then I'm off to buy Tein Springs and Tokico blues :)
Youre in California
Be very very weary around cops
basically anything not white in the front will get you pulled over. I went with 8000k foglights on my solara and they got me pulled over CONSTANTLY. I can only imagine how bad it would be with 12000k
Heres an example of my 6000k headlight/8000k foglight combination
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby TLMNICK » Wed Jun 10, 2009 12:14 pm
Purple headlights are garbage. Especially when you're talking about a non-HID purple. It'll attract a lot of attention from a distance, but you'll be constantly checking your headlights to see if they're on.
I'm all for the yellow fogs though :)
TLMNICK
