SolaraGuy.com • View topic - rim/tire fitting question
Postby freshdenamufcka » Thu Jul 02, 2009 10:58 am
im looking to get these rims but they only offer it in 18x7.5 40+ offset for my car. i'd like to get them in 19's but not sure how it will fit. also what size would my tires need to be? heres the link:
http://www.tirerack.com/wheels/WheelClo ... howRear=no[/url]
freshdenamufcka
Postby yaddadaimsayin » Thu Jul 02, 2009 2:29 pm
derno but those are some clean rims.
Postby ThatVietGuy » Thu Jul 02, 2009 3:09 pm
I fit 235/50/18 and 225/50/18 just fine on my wheels.
ThatVietGuy
Postby indiglosolara » Thu Jul 02, 2009 3:28 pm
225/40/18 is closest to stock size
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Chinky420 » Thu Jul 02, 2009 7:59 pm
i think 19's might rub w/o fender rolling
but i'm still on stock.....so you may want to double check that before committing to 19's
Chinky420
Postby RandySolara » Thu Jul 02, 2009 8:35 pm
ThatVietGuy wrote:I fit 235/50/18 and 225/50/18 just fine on my wheels.
What's ur suspension setup ? if ur spring/shock are stock then it will fit ok ? this pro guy told when we were testing.
indiglosolara wrote:225/40/18 is closest to stock size
Yep yep, i did a test on wheel fitment, 225/45/18 = exactly fit to gen1 stock wheel 205/60/16 with all stock suspension, if u lowered, cant.
Rim 19 will get rub, unless tire is 30, 225/30/19 and ofcourse stock suspension.
RandySolara
BAN sticked
Postby ThatVietGuy » Thu Jul 02, 2009 8:44 pm
Oops, I'm running 40 series, not 50 series tires.
235/40/18 front, 225/40/18 rear.
ThatVietGuy
Postby indiglosolara » Thu Jul 02, 2009 11:56 pm
on 19" wheels you should run either 225/35/19 or 235/35/19 to get close to stock. 30 series it too little.
Dont forget width of your wheels will plan a big facter in the tire size you run.
i've gone thru so many sets of wheels and tire combos in my solara's past..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby RandySolara » Fri Jul 03, 2009 12:12 am
indiglosolara wrote:on 19" wheels you should run either 225/35/19 or 235/35/19 to get close to stock. 30 series it too little.
As you have gone thru many sets of wheel/tire, which one is bestest for 18 rims with Stock Suspension 225/40/18 or 225/45/18 ?
PS: i dont want the rubbin issue to happen aswell.
RandySolara
BAN sticked
Postby indiglosolara » Fri Jul 03, 2009 10:14 am
rubbing issues is going to depend on the size wheel and offset your are going to run. with 225/40 or 225/45 you shouldn't have problems since you are increasing the side wall size. Not the width of the tire. I would say stick with 225/40 if you are going to be concerned with clearance issues.
example would be if you are running a 18x7.5" wheels with a +40 to +42 offset and a 225/40 tire you will not run into rubbing issues on both stock and lowered suspension.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby freshdenamufcka » Fri Jul 03, 2009 11:56 am
im lowered on tockiko/tein s
the specs of the wheels are
19x8
+45
5-114
freshdenamufcka
Postby indiglosolara » Fri Jul 03, 2009 3:35 pm
8" +45 is sitting pretty close to the strut...
I would use a 5mm spacer to push the rear out and run a 225/35 tire or 235/35 tire.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby RandySolara » Fri Jul 03, 2009 8:16 pm
indiglosolara wrote:rubbing issues is going to depend on the size wheel and offset your are going to run. with 225/40 or 225/45 you shouldn't have problems since you are increasing the side wall size. Not the width of the tire. I would say stick with 225/40 if you are going to be concerned with clearance issues.
Thanks for ur great info bro, appreciated ! ill go with 225/40/18 +42 offset.
RandySolara
BAN sticked
Postby freshdenamufcka » Sat Jul 04, 2009 2:15 am
hey randysolara whats up with the thread jacking? anyway...
indiglosolara wrote:8" +45 is sitting pretty close to the strut...
thx indigo, how big of a spacer would i need to get these to sit flush, i understand that i also probably would need to roll my fenders
freshdenamufcka
Postby indiglosolara » Sat Jul 04, 2009 11:10 am
freshdenamufcka wrote:hey randysolara whats up with the thread jacking? anyway...
throw a 10mm spacer on to push it out to +35 offset. If you want to be sitting flush without doing too much modding.. a light fender roll would help with rubbing.
if you want a more aggressive approach with a 8" wide wheel, If it were me I would put a 20mm spacer to push it to +25 offset and run a 225/35 tire that has a natural curved side wall like the Dunlop DZ101's do or Toyo t1r's.
Just as example I am running 8.5" wide all around however I have a +25 offset in the rear and a +40 offset in front running 225/45 falken 912 tires without any spacers and I get a little rubbing in the back if I hit big bumps. I am also cut ALL the way to the edge on my rear fenders with a slight pull with my fender roller. I was previously running a 215/45 tire but changed when I needed to get new tires.
I also rub in the back due to the fact that I am on JIC coilovers and I am DUMPED. I have no gap in the front or back. rear tire tucks when I have ppls in the back. My drop is about 3" as of right now. I may be going lower in the front once i get things adjusted.
indiglosolara
Solara 2 xB
Solara 2 xB
