SolaraGuy.com • View topic - Ride feel with Tein S-techs...
Postby FFguy808 » Fri Jul 03, 2009 10:25 pm
Hows the ride feel for a Gen.1 Solara with Tein S-Techs on stock shocks...im on the budget and just wanna know you guys opinions.. :D
FFguy808
Postby Mr_Krispy1183 » Fri Jul 03, 2009 10:36 pm
I liked my S-Tech's ride, but then again, I'm on Tokico HPs as well.
Postby FFguy808 » Fri Jul 03, 2009 10:46 pm
does it absorb bumps like the stock and does it feel like stock?
FFguy808
Postby Mr_Krispy1183 » Fri Jul 03, 2009 11:10 pm
They're defintely stiffer than OEM, but in a good way. It is a lot more forgiving of the progressive rates that are wound into the Teins than worn OEM struts, which would likely blow prematurely due to the Teins being more aggressively rated than the stock coils.
Postby indiglosolara » Fri Jul 03, 2009 11:11 pm
Teins to me felt almost stock.. but I know they were a little stiffer.. so you don't get the boat like ride the stock springs did..
If you do just springs do the struts too. shell out the extra $300 bucks and do it all at once..
it makes a big diff.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Toy1mzfe » Fri Jul 03, 2009 11:15 pm
I have teins with stock shocks.
They feel like stock ride but a lil firmer.
If u think ur shocks are in good shape, go ahead and go stock.
Postby FFguy808 » Sat Jul 04, 2009 12:35 am
are the eibachs progressive springs like the teins?
FFguy808
Postby Mr_Krispy1183 » Sat Jul 04, 2009 8:57 am
They are, but they'd likely be a less sporty, more OEMish feel. I wish I could tell you, but my current suspension setup is a hybrid of the two you're asking about:Teins up front, Eibachs out back.
Postby yaddadaimsayin » Sat Jul 04, 2009 9:59 am
Mr_Krispy1183 wrote:They're defintely stiffer than OEM, but in a good way. It is a lot more forgiving of the progressive rates that are wound into the Teins than worn OEM struts, which would likely blow prematurely due to the Teins being more aggressively rated than the stock coils.
sounds dangerous! is this a problem that is likely to happen or a rare occurence? i picked up some springs but my stock struts still seem okay so I was plannin on putting the springs over the struts till they're worn. bad idea?
Postby FFguy808 » Sun Jul 05, 2009 11:32 pm
mostly everyone is recommending eibach on tokico shocks...how about Tein S-techs on Tokico?
FFguy808
Postby t3chnique » Sun Jul 05, 2009 11:40 pm
FFguy808 wrote:mostly everyone is recommending eibach on tokico shocks...how about Tein S-techs on Tokico?
if you want a raked stance, go with TEIN.
if you want an even drop, go with Eibach
t3chnique
Postby Solarizona » Sun Jul 05, 2009 11:51 pm
Eibach gets my vote! Tein are generally too soft for me.
Solarizona
Postby Mr_Krispy1183 » Mon Jul 06, 2009 12:08 am
if you want an even drop, be OCD like Krispy and buy Teins, buy Gold-Line & Eibach rears in search of the best possible rear lowering, and sell the Tein rears to try and curb the costs
fixed, lol :drinking:
Postby Pogs » Mon Jul 06, 2009 3:48 am
My teins settled pretty even. Just remember that if you have a system in the back it will lower your back a little bit more.
BTW im running Teins and GR2s
Search and Win
Pogs
Postby jaskaran » Wed Jul 08, 2009 12:05 am
yeh i got mine on teins too but i changed the struts too so it feels like stock the ride is really smooth if ur struts are in good shape go for it
jaskaran
