SolaraGuy.com • View topic - EXCITED! Found a great Performance shop. Custom Intake!!!
Postby ampreston85 » Tue Jul 07, 2009 11:22 pm
So I've decided that my first real aftermarket mod to accompany my Denso Iridium plug replacements and Magnecor Wires, is going to be a custom fabricated FULL CAI! I found a place that HorsePower Freaks actually recommends all their customer to, to have custom fabrication and/or install done. They are called FORGED PERFORMANCE. Gonna be full CAI, dropped down below the fog light i believe... They are gonna draw up all my options tomorrow. Bypass valve, Hydro shield, the whole nine yards. I'm way excited. Anyone else here have a full CAI? Pix would be great, post your pix of your intakes. Can't wait to post results myself
ampreston85
Postby D-money » Tue Jul 07, 2009 11:30 pm
Congrats i have the cai and i love it im sure you will love yours here is a pic of the parts you can see i dont feel like taking the liner off to get a pic of the down stairs part.Image
D-money
Postby aenties » Wed Jul 08, 2009 8:21 am
Looking forward to that cai.
'98CamryLEV6:
Tokico,Eibach,TrdRSB,Intake,Jim'sTorqueRod.
aenties
Postby Midias » Wed Jul 08, 2009 9:20 am
I had a full cai very easy to make only 1 45 degree from the TB then a straight with a maf adapter then a 90 degree bend into the muffler. Here is my first incarnations using the stock resonator for a less buzzy sound. Later I used matching couplers and a pipe in place of the resonator but found no gain. It was extremely easy to do.
Postby Midias » Wed Jul 08, 2009 9:21 am
I would get the OBX intake and have them build off that it will save cash and make sure you have the correct MF adapter.
Postby Chinky420 » Wed Jul 08, 2009 10:24 am
make sure they use 2.75" piping
3" will throw a CEL
3" CA extension will not fit into the fender (without cutting through your engine bay)
3" will need a retune of a/f ratios to prevent throwing a CEL
just curious...how much are you planning on spending for this custom CAI setup?
and you should dyno your car before/after, and then compare to CP-E results to see if the CP-E is better, worse, or about the same as the custom setup.
Chinky420
cel
Postby NRDriver » Wed Jul 08, 2009 7:03 pm
i have a weapon r 3" intake and a 3" extension that i made myself. as soon as i put on the extension i get a po171 code/lean bank 1. is this a common issue?
NRDriver
Re: cel
Postby Midias » Wed Jul 08, 2009 7:07 pm
NRDriver wrote:i have a weapon r 3" intake and a 3" extension that i made myself. as soon as i put on the extension i get a po171 code/lean bank 1. is this a common issue?
Do you have the weapon R with the tube in a tube?
Postby ampreston85 » Wed Jul 08, 2009 7:16 pm
what does throw CEL mean? lol still learning here
ampreston85
Postby GreeKAvaLoN » Wed Jul 08, 2009 7:25 pm
cel = check engine light. i have an injen and never had a cel or a problem excep it gets reallly hot =[
GreeKAvaLoN
Postby ampreston85 » Wed Jul 08, 2009 7:27 pm
Aw i see. i don't need that lol
ampreston85
Postby bbq bob » Wed Jul 08, 2009 8:00 pm
i have the enjen and cold air extension. does not get hot because of the cold air feature. there are some pic's at the introduction section under bbq bob is in the garage page 3
bbq bob
Re: cel
Postby Pogs » Thu Jul 09, 2009 3:29 am
arent they all like this....to create the turbine/vacuum tunnel
Search and Win
Pogs
