SolaraGuy.com • View topic - Which wire on the Ignitor is the tach signal?
Postby trd4life » Tue Jul 14, 2009 9:29 am
Hey guys i am wiring up a nitrous kit right now and need to know which wire on the ignitor is the tach signal, anyone know?
thanks
Postby JamesT » Tue Jul 14, 2009 9:32 am
What year is the car - I can run outside and look at my harness diagrams if it helps.
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby yaddadaimsayin » Tue Jul 14, 2009 9:50 am
trd is asking for help from the commonfolk??
Postby trd4life » Tue Jul 14, 2009 9:51 am
99 1mz-fe solara
I tapped into the green wire on the ignitor which doesnt seem to work.
thanks so much!
Postby 1gSE » Tue Jul 14, 2009 9:54 am
when i wired in my aem fic i tapped the crank sensor wire going into the ECU....im at work right now, but if you don't get an answer, i'll let you know later
...IIRC it was green too :o
::edit::
wait, that might have been the color of the wire on the fic....
Solara-M62 @ 5.5psi
1gSE
Postby TLMNICK » Tue Jul 14, 2009 10:24 am
If it's a 1MZ, then you're going to want to use the black wire as a tach signal.
TLMNICK
Postby trd4life » Tue Jul 14, 2009 10:37 am
Black wire on the ignitor correct?
thanks
Postby trd4life » Tue Jul 14, 2009 10:47 am
i see a black/red on the ignitor
Postby JamesT » Tue Jul 14, 2009 11:03 am
trd4life wrote:i see a black/red on the ignitor
Black/red should be right. If it doesn't work, let me know.
BespokeAutoInterior
JamesT
Postby trd4life » Tue Jul 14, 2009 2:26 pm
hmm still no luck i'm wondering if i need a MSD tach adapter so the window switch gets an accurate signal.
Postby GzNutz » Tue Jul 14, 2009 2:50 pm
Are you going two stage?
Postby trd4life » Tue Jul 14, 2009 3:05 pm
nope single wet 90 shot for now until i get the Eaton M90 Supercharger that i am fabricating on the car.
Postby GzNutz » Tue Jul 14, 2009 3:21 pm
Nice!
Postby JamesT » Tue Jul 14, 2009 4:05 pm
trd4life wrote:hmm still no luck i'm wondering if i need a MSD tach adapter so the window switch gets an accurate signal.
Just to verify with what I have, what are the colors of the wires?
The red/black goes to the starter.
BespokeAutoInterior
JamesT
Postby 1gSE » Tue Jul 14, 2009 4:25 pm
try at the harness going into the ECU. The 4th connector (D) pin 16..should be black and red
Solara-M62 @ 5.5psi
1gSE
