SolaraGuy.com • View topic - Which camber kit??
Which camber kit??
Which camber kit??
Postby SleeperSolara » Tue Jul 14, 2009 5:14 pm
Well i'm in a need of a camber kit.
I'm goin' to get a full set, [front and rear kits, both bolts].
I've been lookin' at some camber kits.
There are Eibach's camber kit and Ingalls camber kit.
Eibach's camber kit offers: +/- 1.75, it replaces the top bolt only [same for rear]. Cost: $29.00 for a pair.
Ingalls camber kit offers: +/- 2.00, it replaces the top and bottom bolt [same for the rear]. Cost: $22.00 for each. $11.00 for the upper bolt only.
Prices are from: http://www.tirerack.com/suspension/Susptabl.jsp?autoMake=Toyota&autoModel=Camry+Solara+SE&autoYear=2000&autoModClar=&brand=&category=Alignment
Whiteline camber kit: +/- 1.75, it replaces the top bolt only. [same for rear]. Cost: $79.63 for a pair. 15mm is for the front, 17mm is for the rear.
Prices are from: Global Performance Parts. The Whiteline camber kit is back order from Global Performance Parts.
I would like some input about the camber kits i've provided.
I was thinkin' about Ingalls camber kit, but would like some input.
Thanks.
Postby Mr_Krispy1183 » Tue Jul 14, 2009 8:38 pm
I'm sure you don't need more than +/-1.75 deg. of correction. I have the same suspension setup as you, but only need the camber kits because of the spacers/low wheel offsets, which require negative camber to clear the fenders. Whiteline and Eibach source said bolts from SPC, which produces them and sells them as well.
Postby SleeperSolara » Wed Jul 15, 2009 7:04 am
Mr_Krispy1183 wrote:I'm sure you don't need more than +/-1.75 deg. of correction. I have the same suspension setup as you, but only need the camber kits because of the spacers/low wheel offsets, which require negative camber to clear the fenders. Whiteline and Eibach source said bolts from SPC, which produces them and sells them as well.
I see.
I'm rollin' on the TRD Revo rims.
Oh really??
I didn't know that.
Postby CamryOnBronze » Wed Jul 15, 2009 7:51 am
I would think you would be able to get the car into spec with such a mild drop. If they are saying you need a camber kit to get your camber into spec with just tein springs, then something is wrong. They got my camber into spec dumped on coilovers without one, so I don't think you really have a need for it.
Postby indiglosolara » Wed Jul 15, 2009 9:59 am
I have a set of front and read chamber kits for sale. I bought them a while back to use however I ended up getting a set of coilovers with chamber plates.
Looking to get what i paid..
I bought them from SPC.. I dont have the OE box anymore but if you are interested hot me up.
But the specs when I order mine were +/- 1.75 degrees front and rear
indiglosolara
Solara 2 xB
Solara 2 xB
Postby SleeperSolara » Wed Jul 15, 2009 3:29 pm
CamryOnBronze wrote:I would think you would be able to get the car into spec with such a mild drop. If they are saying you need a camber kit to get your camber into spec with just tein springs, then something is wrong. They got my camber into spec dumped on coilovers without one, so I don't think you really have a need for it.
Yeah i thought so too, but lately i just noticed my camber really is really off.
I did take it to Hibdon's here, and they said the had put the camber to the max as close to OEM specs.....
They said it could be that the OEM camber bolts are worn out??
indiglosolara wrote:I have a set of front and read chamber kits for sale. I bought them a while back to use however I ended up getting a set of coilovers with chamber plates.
Oh??
I see.
Will do.
Ok.
