SolaraGuy.com • View topic - Rear sway bar question
Postby mers714 » Fri Jul 24, 2009 11:23 pm
so i bought a trd rear sway bar today and i tried to install it, couldnt do it :cry:
is it safe to drive without a sway bar for about 5 miles to a mechanic?
2000 Solara V6 SE AUTO - TRD RSB - TINT - 6K HID's
mers714
Postby SdeA » Sat Jul 25, 2009 12:23 am
It should be fine.
SdeA
Postby djandrey_M » Sat Jul 25, 2009 12:47 am
Why couldn't you install it?
djandrey_M
Postby 99BlackSandv6 » Sat Jul 25, 2009 1:21 am
Yeah, the car will handle like >>I'm a douche<<, but you can drive it like that. I had some tough times installing mine too. It seemed like nothing fit quite right, but I finally got her on there. You'll be happy with the change in handling once you get it installed. Good luck!
Postby youngblood » Sat Jul 25, 2009 8:17 am
Yup- no problem driving it that way. Lot's of older cars don't have a sway bar at all.
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby mers714 » Sat Jul 25, 2009 8:25 am
okay thanks for the replies
it was so frustrating, everything wouldnt line up
mers714
Postby SleeperSolara » Sat Jul 25, 2009 10:11 am
If it doesn't line up one way flip it, and try it the other way.
Postby unbalancedwood » Sat Jul 25, 2009 10:36 am
What it is also is that the strut and spring setup is hanging down lower then normal, you need an additional jack to compress it upward or just lower your car with the wheels and everything on the car so the holes line up
unbalancedwood
Postby mers714 » Sat Jul 25, 2009 10:51 am
thanks for the advice but after working on it for 4 hours yesterday i give up haha im taking it to my mechanic right now :D
mers714
Postby 99BlackSandv6 » Sat Jul 25, 2009 11:05 am
Took me about a week to install mine, long story. I broke some stuff and had to fix it. But it was all worth the trouble in the end.
Postby mers714 » Sun Jul 26, 2009 1:59 am
i got the rsb installed today, its a major difference handles a lot better
im going to lower it next week :D
mers714
Postby 99BlackSandv6 » Sun Jul 26, 2009 2:06 am
Told you so. Enjoy!
Postby mazen222 » Sun Jul 26, 2009 8:50 am
cant wait to buy one... the feedback from you guys on this sway bar has always been extremly positive
1999, 5 Speed V6
mazen222
Postby youngblood » Sun Jul 26, 2009 9:21 am
mers714 wrote:i got the rsb installed today, its a major difference handles a lot better
You're going to lower it or your mechanic is going to lower it? :D
Just busting your balls over here!
youngblood
Postby Taido » Sun Jul 26, 2009 9:44 am
The sway bar feels wonderful. I finally heard the rear wheels squeal a little as I was switching interstates. My friend in his Mustang was lagging behind on the turns. :P
Taido
Audiophiliac
Audiophiliac
