SolaraGuy.com • View topic - Do G35 Rims fit
Do G35 Rims fit
Do G35 Rims fit
Postby SpeedySolara » Fri Jul 31, 2009 10:28 pm
I found a good deal on G35 rims but was wondering if they fit and/or if they will rub. I'm dropped on Tokico Blue Struts and TRD Springs. please chime in guys. If my research is correct the G35 rims measure 225/45/18x8, maybe 225/50/18x8 if staggered. I think it will fit but you guys probably know better.
SpeedySolara
Postby PXLpainter » Fri Jul 31, 2009 10:33 pm
It's also about the offset. G35 rims are about -30. There's lots of wheel/tire fitment guides posted up here on SG so it might be good to do some reading. :up:
Postby SpeedySolara » Fri Jul 31, 2009 10:37 pm
I was reading on both the measurements of the G35 rims and what others have put on the Solara. From the looks of it, people haven't done this to the Gen 1 and for those that have gone bigger got their fenders rolled. Maybe you could help. I know the G35 has the same bolt pattern but my concern is rubbing. Do you think it will rub?
SpeedySolara
Postby Toy1mzfe » Fri Jul 31, 2009 11:54 pm
From what i heard from MILT.
Yoy need to run smaller tires and roll your fenders to get them to fit.
Postby ~SolaRaSpeed~ » Sat Aug 01, 2009 12:00 am
i think thatvietguy has g35 wheels on his car not sure about setup but i bet it's in his posts somewhere.
~SolaRaSpeed~
Postby ThatVietGuy » Sat Aug 01, 2009 1:33 am
PXLpainter wrote:It's also about the offset. G35 rims are about -30. There's lots of wheel/tire fitment guides posted up here on SG so it might be good to do some reading. :up:
PLUS (not MINUS) 30 ;)
I run G35 SEDAN wheels. They fit just fine, almost zero rubbing when I was still lowered on coilovers.
If you're talking about the COUPE wheels, they probably will fit, but you'll probably need a fender roll.
ThatVietGuy
Postby SpeedySolara » Sat Aug 01, 2009 4:17 pm
size confirmed 225/45/18 so i should be good. Someone confirm?
SpeedySolara
Postby Mr_Chunkz » Sat Aug 01, 2009 8:59 pm
SpeedySolara wrote:size confirmed 225/45/18 so i should be good. Someone confirm?
run a 225/40, that would be better imo
I run that tire size on my solara with 18x7.5
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby SpeedySolara » Sat Aug 01, 2009 10:56 pm
The only problem with that is I'd have to buy 4 new tires and for that I just buy a whole new set of rims. :evilbat:
SpeedySolara
