SolaraGuy.com • View topic - automatic. tranny problem
Postby scuba » Mon Jul 21, 2003 1:43 am
ok lately ive been having a problem with my transmission. my friend at the toyota dealer ran a obd 2 test( i think thats what its called) on it and he said it was the E shift silenoid problem...anyways i took it to the dealer they cleaned out the sileniods and then they gave it back and then the enigne check light came back up..then i took it back agian and they ordered new shift assemably and i dunno what that is but yah they installed that. it seemed like it was working fine until yesturday when i found out i have no forth gear. for those who dont know i have a solara automatic with a supercharger... well i found out that i have no forth gear cause i topped out at 120.. and that cant be right cause ive gone faster. but yah i counted from first gear and there was only two shifts and it just stayed in third and redlined..well basicly does anyone know what problem i am having.. its weird cause the engine check light isnt even on.. my friend said that overdrive is off but there is nothign indicating that so i dont know what is going on. if anyone can help i would really appricate it
scuba
Postby hari-bhari » Mon Jul 21, 2003 4:50 am
sorry to hear about ur problems. it basically sounds like overdrive isnt engaging, beacuse overdrive is the fourth gear. normally when you disengage overdrive by pushing that button, you'll hear your engine downshift into third. but im sure u knew that already. my best guess is that its just a simple electronics issue, where ur computer thinks that o/d switch is disengaged, so its tellin the tranny not to go into fourth. i would try pushing the o/d button on your gear shifter a few times, to see if theres any difference when its pressed or not. and see if the o/d off lights up in ur dashboard display. in the meantime, i would recommend not redlining your engine or straining it too much in third gear (or any gear, for that matter) , because the last thing you want is a blown engine. good luck. p.s. i hope ur car is under 60k, so ull still have warranty.
hari-bhari
Postby scuba » Mon Jul 21, 2003 9:22 am
thanks. well do u think if i reset the ecu that might help. yah my cars under 60k. but im just tired of taking it to the dealer and them saying that they fixed it
scuba
Postby hari-bhari » Mon Jul 21, 2003 12:47 pm
honestly, i know nothing about resetting an ecu and what effects it might have....i kno dealers are a pain, but you need to take it to them, tell them to hop in the car with u, and count the shifts for them, to prove it. take it up to redline if necessary (but dont hold it there too long) to show them that it wont shift out of third. this way theyll have no excuse not to fix it
hari-bhari
Postby Ragtop George » Mon Jul 21, 2003 1:45 pm
You don't need to redline the engine to check shifts! Use your tachometer. If you have 4th gear, you should be at 2500 RPM or so at 60 MPH. If you are closer to 3500 RPM, then you are in third.
George
2002 Solara Convertible Automatic
TRD Supercharger, 6 PSI pulley
Apexi WS exhaust, custom Y pipe
TRD RSB on "track" setting
Ragtop George
Postby Jai_Jai_Binks » Mon Jul 21, 2003 2:35 pm
Ragtop George wrote:You don't need to redline the engine to check shifts!
Exactly! But i think he pretty much knew that wasn't norm...hence his post...
To reset your ecu, disconect your negative from the batter and keep it disconnected for a min 5 minutes and then reconnect n work ur way from there....
Postby scuba » Mon Jul 21, 2003 6:17 pm
well i took it to the toyota dealer today..i told them the sutuation and they checked it out. turns out the transmission was blown(which i told them from the beganing) so yah they are ordering that so hopefully i get my car back before the 8th gen solara comes out
scuba
Postby hari-bhari » Mon Jul 21, 2003 6:29 pm
oh man, that sux. well at least itll be fixed. any word on how it got blown? thats really odd for a toyota. so did they give u a loaner car, or u gotta pay out of pocket?
hari-bhari
Postby impactX » Mon Jul 21, 2003 8:44 pm
scuba wrote:well i took it to the toyota dealer today..i told them the sutuation and they checked it out. turns out the transmission was blown(which i told them from the beganing) so yah they are ordering that so hopefully i get my car back before the 8th gen solara comes out
Why did it blow? How much mile did you put on it?
Anyways, 4th gear should be around 2100RPM at 60mph
impactX
Postby scuba » Tue Jul 22, 2003 12:46 am
no loner car. i didnt mean it was blown. what i meant to say was that it was just totaly not fixable. so i needed a new one.
scuba
Postby scuba » Tue Jul 22, 2003 12:47 am
im getting tired of this car. i want to my solara fast but shti too much money for not enough gain. i dunno i might just end up selling it
scuba
Postby hari-bhari » Tue Jul 22, 2003 4:19 am
scuba wrote:im getting tired of this car. i want to my solara fast but shti too much money for not enough gain. i dunno i might just end up selling it
yea i felt the same way for a while. but then one thing you have to realize and accept is that our cars are sporty luxury cars, that are fun to drive. they are not hardcore sports cars. so you really have to decid what you want. personally, i love the way the ride is so smooth, and the car is big, with a backseat ppl can actually sit in. the interior is quiet, and the engines are nice. so for me, that's good enough. i dont think ull ever find a true sports car that rides quieter or smoother than the solara, unless u start paying thousands more for a g35, etc.
hari-bhari
Postby scuba » Tue Jul 22, 2003 7:52 am
true, the solara is a nice car but man the dealership is so trying to screw me over..they just called me an hour ago saying that because i replaced the shift knob that that is the reason that the tranny isnt going into forth. they wanted me to bring down the orignal shift knob. i am so close to trading in my car at some dealership cause i know im gonna get screwed into paying a huge fee thats not gonna be worth it
scuba
Postby hari-bhari » Tue Jul 22, 2003 9:57 am
hey look in the aftermarket upgrades section. theres a sticky about the magnuson-moss act. it basically states that they cant void ur warranty saying that you installed some aftermarket part that was not related to the problem. obviously the shift knob, a DECORATION piece at the top of ur lever can't affect your transmission. print out the thread for them if u want and let them have a look. they cant wiggle out of fixing ur transmission :x
hari-bhari
Postby DavPak » Tue Jul 22, 2003 10:26 am
hari_trivedi wrote:hey look in the aftermarket upgrades section. theres a sticky about the magnuson-moss act. it basically states that they cant void ur warranty saying that you installed some aftermarket part that was not related to the problem. obviously the shift knob, a DECORATION piece at the top of ur lever can't affect your transmission. print out the thread for them if u want and let them have a look. they cant wiggle out of fixing ur transmission :x
um, i think you're forgetting that the problem is with 4th gear (aka overdrive). the aftermarket shifter many times relocates the overdrive switch. hence, that COULD be the problem. it sounds like the dealer merely wants to have the OEM shifter in order to see if that's what the problem really is.
yikes, always lookin to point the finger at the dealer.
what bugs me more is that there are other dealers out there that are scumbags and give dealers like mine a bad name :evil: :evil:
'02 Solara S/C'ed V6 5-spd
DavPak
