SolaraGuy.com • View topic - need to upgrade fuel pump with 50 shot dry nitrious system?
Postby corlon » Thu Aug 06, 2009 10:56 pm
anyone know if its needed or recommended to upgrade any part of the fuel delivery system on v6 manual 1st gen when running a 50 shot of dry nitrious?
NiCe
corlon
Postby kenlrw39 » Thu Aug 06, 2009 11:08 pm
I'm running a 75 dry shot on stock fuel sytem just get one step colder plugs and run 101octane or higher and you'll be fine. oh i would recommend a window switch cuz its a good safety feture. I've put 2 bottles through my engine in 2 weeks and its running like a champ. But i think alot of ppl on here will recomend it.
kenlrw39
Postby 1gSE » Fri Aug 07, 2009 2:32 am
it could probably be done. A 190 walbro cost less than $100, and the install looks like it can be done in about half an hour..better safe than sorry
Solara-M62 @ 5.5psi
1gSE
Postby corlon » Fri Aug 07, 2009 3:09 pm
can anyone list the brand and part number of the rpm window switch their using?
NiCe
corlon
Postby GzNutz » Fri Aug 07, 2009 3:16 pm
NOS #741-15982
Postby kenlrw39 » Fri Aug 07, 2009 4:26 pm
Hers what I'm runnin
nitrous system is NOS power shot dry
Sparkplugs are autolites pt#3922
and window switch is Nitrous outlet brand dual stage rpm window switch i got it on this site www.nitrousoutlet.com
but they sell basic switches on summit racing for 60bucks.
kenlrw39
Postby trd4life » Fri Aug 07, 2009 7:41 pm
For you running the dry setup, how are you providing the fuel enrichment when the nitrous activates? spraying the maf?
Postby kenlrw39 » Fri Aug 07, 2009 9:43 pm
Mines is taped into the airbox spraying about 3-4in from the maf
kenlrw39
Postby corlon » Fri Aug 07, 2009 9:59 pm
the system i'm looking at has a selonoid for the fuel as well as the nitrous.
also. wouldn't you want to spray the nitrous between the mass airflow sensor and the throttle? and not in front of the maf.
NiCe
corlon
Postby kenlrw39 » Fri Aug 07, 2009 10:06 pm
That would be a wet sytem your looking at and yes you would wanna spray it after the maf because that extra selonoid add the fuel but for a dry system you only have a nitrous selonoid so you relly on your maf to increase fuel.
kenlrw39
Postby corlon » Fri Aug 07, 2009 10:09 pm
gotcha. thanks.
NiCe
corlon
Postby kenlrw39 » Fri Aug 07, 2009 10:20 pm
And I'll drop this now cause it took me forever to find if your gonna run a window switch on a gen 1 the rpm wire is the orange and black wire on the ecu i believe in the second connector from the top it took me 3 days to track that info down.
kenlrw39
