SolaraGuy.com • View topic - Do PXLs g35 17's fit our gen 1s?
Postby LatinUSMC » Mon Aug 10, 2009 12:06 pm
I SEARCHED BUT I STILL COULDN FIGURE IT OUT...ANYONE?
http://www.solaraguy.com/viewtopic.php?t=36863
http://www.solaraguy.com/viewtopic.php?p=538416#538416
This is a quick-reference link to check out BEFORE you feel compelled to ask the question, "Will these wheels/tires/offset work on my Solara?"
First - the various size/fitment calculators out there:
http://www.1010tires.com/TireSizeCalcul ... ion=submit
http://www.net-comber.com/tirecalc.html
http://www.miata.net/garage/tirecalc.html
General Terminology:
http://www.solaraguy.org/viewtopic.php?t=29865
Offset & Backspace Explained:
https://www.rsracing.com/tech-wheel.html#backspace
Next, the thread with all the hard-core info that will explain it all for you:
http://www.solaraguy.org/viewtopic.php?t=19601
Read it.Learn it.Live it.
LatinUSMC
Postby Mr_Krispy1183 » Mon Aug 10, 2009 12:10 pm
Josue, I believe they should fit. If anything, you MIGHT need spacers, but that's all.
Postby Chinky420 » Mon Aug 10, 2009 3:51 pm
josue, i believe i've seen stock g35 wheels on a solara on cardomain.....i can't remember the ride/link, but maybe a pm to pxl would confirm....?
i know stock IS300 wheels fit...but that does not help answer your question. lol.
Chinky420
Postby indiglosolara » Mon Aug 10, 2009 4:02 pm
i thought he had the 18" wheels not 17"
indiglosolara
Solara 2 xB
Solara 2 xB
Re: Do PXLs g35 17's fit our gen 1s?
Postby djandrey_M » Mon Aug 10, 2009 4:42 pm
LatinUSMC wrote:I SEARCHED BUT I STILL COULDN FIGURE IT OUT...ANYONE?
The hard core info link doesn't work. I'm too trying to figure out what wheels to buy but that link doesn't work so yeah.
Hey, I got a question, I hope someone can give me some advice on this one: how do I make sure that I won't get some kind of irreparable wheels that have been bent or messed up beyond repair somehow that a guy on craigslist is just trying to offload?
djandrey_M
Postby PXLpainter » Mon Aug 10, 2009 4:50 pm
Guys - it's all math.
Don't you usually need spacers for Gen 2 wheels? That's because Gen 2 wheels have less offset than Gen 1, right? (40mm offset)
These are 30mm so just the opposite as they are pushed out farther to the outside, so if you usually get 5-10mm spacers then this would do the trick.
The only question then would be is 8" too wide and what size tires you'll want? These are 18x8 offset 30
If you know your current (stock) wheel/tire info, then go here and plug in the numbers!
http://www.rims-n-tires.com/rt_specs.jsp
Keep in mind that I won't be able to use your Gen 1 rims unless they match Gen 2 specs. ;)
(17x7 offset 40)
Postby Mr_Krispy1183 » Mon Aug 10, 2009 5:09 pm
^Jeff,
If they are 18x8 +30, then that's great! You should be good Josue, you just need someone to roll your rear fenders.
And Josue's TRD Revos should be 17x7 +40, so PXL would be good too.
Postby PXLpainter » Mon Aug 10, 2009 5:28 pm
Lemme know ASAP before I just turn it in with these on the ride!
Postby Toy1mzfe » Mon Aug 10, 2009 5:51 pm
THEY will fit.
U just need hub rings, smaller tires, and roll fenders.
Spacers are not needed.
I have 18x8.5 in the rear and its fits snug with shaved fenders.
According to . http://www.1010tires.com/WheelOffsetCalculator.asp
the rears will fit but must have the fenders modified.
The front on the other hand may stick out a bit more. Since my fronts are 18x8 +45 i kno they can be pushed out more but not sure how much.
Postby PXLpainter » Mon Aug 10, 2009 6:10 pm
These are all 18x8 30 offset (not 8.5 w)
If you're running 225/45/18s you should be okay as they will be about 5mm further in than Gen 2. Wider tires will cause issues.
Postby LatinUSMC » Tue Aug 11, 2009 11:17 pm
I CANT BELIVE NONE HAS JUMPED AL OVER THESE..IM SO DAMN BROKE. :-?
LatinUSMC
Postby Projex0 » Wed Aug 12, 2009 12:15 am
i did lol
Projex0
Postby mightymouse402 » Wed Aug 12, 2009 1:12 am
i saw PXLpainter on the 210 today at around 8 o clock... first time i've seen a fellow SG on the freeway or something like that... =o)
That's what she said...
mightymouse402
