SolaraGuy.com • View topic - Clunk From TRD RSB, Gen 1
Postby 99BlackSandv6 » Tue Aug 11, 2009 11:42 pm
I have the TRD RSB installed on my Gen 1, and I have it set to the stiffest setting. I have a pretty nasty clunk all the time now, and can't figure a way to prevent it. The RSB is hitting the inner mounts for the suspension arms, if you are familiar with it I am talking about the two big washers toward the center of the car, directly below the sway bar. If the car were lowered I have a feeling the noise would stop, but I am still working on the funds for that. The noise happens when the suspension extends not when it compresses.
Has anyone else had this problem? If so, any suggestions are welcome.
Thanks,
Ben
I hate suspension noise... :(
Postby LEE337 » Tue Aug 11, 2009 11:47 pm
How old are your struts???
Postby SleeperSolara » Wed Aug 12, 2009 9:07 am
Have you checked the bushin' mounts if they are torqued down tight.
Check the end links also.
If those are not loose.
It could be your strut mount maybe.
Postby ~SolaRaSpeed~ » Wed Aug 12, 2009 10:32 am
i second checking the sway bar end links for play... if not it maybe time to finish saving for some suspension parts.
by the way, do you have a subwoofer box in the trunk?
~SolaRaSpeed~
Postby Midias » Wed Aug 12, 2009 10:46 am
Had the same problem jack up both tires off the ground loosen both up and let it free hang then tighten all of it back down.
Worked for me.
Postby redgen1 » Wed Aug 12, 2009 11:18 am
if that doesnt do it... time to pull the interior and check the strut mounts.
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby 99BlackSandv6 » Wed Aug 12, 2009 7:06 pm
Thanks for the responses. I have the original struts and mounts, 114,000 miles.
I don't think the sound is from the struts, and I checked the end links. Also the bushing mounts are tight. The same sort of sound was going on a while back and it was the end link, but not this time.
I think my best option is to replace the struts and springs from the mounts down. I have been looking into Eibach & Tokico. Only thing is, I don't know where to buy the mounts, I know Tokico makes them but can't find 'em online.
Thanks,
Ben
PS
I don't have subs.
Postby prsolara » Wed Aug 12, 2009 7:46 pm
that is the same sound I have, but mine also make a similar sound in the front, I will check this weekend for all the things posted here when I put the springs on the car.
prsolara
Postby SleeperSolara » Wed Aug 12, 2009 8:21 pm
99BlackSandv6 wrote:Thanks for the responses. I have the original struts and mounts, 114,000 miles.
Thanks,
Ben
PS
I don't have subs.
You can just use the strut mounts from AutoZone or Advance Auto Parts.
Postby 99BlackSandv6 » Wed Aug 12, 2009 8:36 pm
^ yeah, I just don't want any shotty parts on my car. I'll look into it though.
Postby GreeKAvaLoN » Wed Aug 12, 2009 9:12 pm
i've been told KYB mounts are pretty good. I have new OEM toyota up front and original in rear and it sounds like theres children running into my car every time i go over a bump..
GreeKAvaLoN
Postby SleeperSolara » Thu Aug 13, 2009 2:54 pm
99BlackSandv6 wrote:^ yeah, I just don't want any shotty parts on my car. I'll look into it though.
Yeah i know what you mean.
Postby 99BlackSandv6 » Thu Aug 13, 2009 3:56 pm
GreeKAvaLoN wrote:i've been told KYB mounts are pretty good. I have new OEM toyota up front and original in rear and it sounds like theres children running into my car every time i go over a bump..
HAHAHA! That's great..."it sounds like children are running into my car"
Thanks for the help. :lol:
Re: Clunk From TRD RSB, Gen 1
Postby bassthrive » Wed Jul 28, 2010 9:03 pm
Same problem. I have had my rsb for maybe two years now without a problem. Last week it developed a horrible clunk! I changed the setting from track to street. That seems to have fixed it. But I am annoyed now...
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby ThatVietGuy » Wed Jul 28, 2010 9:58 pm
Are you sure the bolts weren't loose before you changed the setting to street?
I had a loud clunk and it was because the bolts holding the endlink to the strut was loose.
ThatVietGuy
