SolaraGuy.com • View topic - Possible new brake upgrade
Postby alltrac92 » Wed Aug 19, 2009 9:07 pm
I have been in contact with www.racingbrake.com I sent them a new reman ES300 dual piston caliper with bracket. They do not use move out brackets to run the bigger Supra rotor. They cast a new caliper bracket so the larger Supra rotor fits. They did a kit for the IS300 guys using Supra rotors. Here are some links with pictures and the benefits of their caliper bracket.
http://forums.racingbrake.com/showthread.php?t=263
http://my.is/forums/f174/racing-brake-o ... ng-367122/
http://www.racingbrake.com/v/main/oe_ca ... ke_kit.asp
Sourcing your own dual piston calipers the price for the brackets are $175 to $200 need a minimum of 30 sets.
The caliper bracket kit with Supra rotors is upgraded from OE straight vane to curved vanes. The curved vanes pump more air and keep the disc cooler than straight vanes. However the curved vane discs are “directional” meaning left and right discs are different and requires two sets of tooling instead of just one set in the case of straight vanes.
Estimate for caliper brackets and curved vane Supra one piece (w/o caliper) will be around $450-500, caliper brackets with two piece Supra rotor kit $700-750 (w/o caliper) two piece rotors have an aluminum hat and are lighter.
There might be a different option, making brackets for the stock single piston calipers using the Supra rotor. My contact likes this idea better as you don't have to spend more money on calipers. here is some of his ideas from emails.
"The Camry rotor is 255mm x28 while the Supra non turbo is 296x32, Supra turbo is 323x30. I think for the non turbo Supra rotor you can get away with a 16” wheel, but for the Supra turbo rotors you will need 17” wheels. This is also something you should consider so you don’t end up spending an additional $1000 for larger wheels (and tire). We see a lot of enthusiasts go through the same exercise just to try and make the kit fit. They end up with more money spent than they expected and still can’t accomplish what they want. That’s what we can help with a solution at low cost with guarantee performance improvement."
"If you are asking my opinion, I would say a single piston (your Camry) can be just as effective as dual piston (older Camry), or 4 piston (Supra turbo), or I should say even if there is a difference of performance, the improvement can't justify the cost, time and trouble in acquiring (upgrading) the calipers."
"If you will track the car what you really need is a bigger and light weight efficient cooling rotors like the Supra two piece. We have numerous applications to prove that, one of them is Acura NSX which we offered OE caliper (single piston) BBK with our center mount design with two piece rotors. Our customers can out brake some of the higher end cars equipped with original Brembo calipers costing thousands of dollars."
I have nothing to gain from this I just sent them the caliper to get their opinion and some options. I can send them a stock front single piston caliper. I just don't know if we can pull together 30 orders and what is preferred. Single piston or dual piston brackets?
alltrac92
Postby SleeperSolara » Wed Aug 19, 2009 9:34 pm
Very nice.
Dang and i just got my twin piston caliper brackets powder coated already.....
Postby LEE337 » Wed Aug 19, 2009 9:47 pm
So you want bigger rotors w/dual piston calipers???
Postby Dawgz » Wed Aug 19, 2009 9:57 pm
Im sure a dual piston setup would out perform a single piston setup
Postby LEE337 » Wed Aug 19, 2009 10:09 pm
Well the ES300 has duals, that fits 99-03 Laras, right?
Postby jetbtkng » Thu Aug 20, 2009 12:54 am
ya gabe sells the big brake kit , twin piston caliper, with supra rotors, and bracket, about $500, bbq bobs got one on his camry, works great, heres the name of post, TRD4life Big Brake Brackets , in for sale section.................. :drinking:
Postby LEE337 » Thu Aug 20, 2009 12:59 am
So the ES300 dual calipers do fit?
Thats what I was tryin to get at.
That type of kit is already avalible. Waitin on my brackets to come in.
$150 for the brackets and $225 for the slotted/drilled TT rotors.
Thats a heck of a deal.
Postby jetbtkng » Thu Aug 20, 2009 1:19 am
talk to gabe he knows........... :drinking:
Postby LEE337 » Thu Aug 20, 2009 1:23 am
^oh yeah, will do 8)
Postby alltrac92 » Thu Aug 20, 2009 9:45 am
LEE337 wrote:That type of kit is already avalible. Waitin on my brackets to come in.
This kit is nothing like what you have mentioned. They can recast either the single or dual piston caliper bracket to allow use of the bigger Supra Rotor.
alltrac92
Postby 99BlackSandv6 » Thu Aug 20, 2009 9:55 am
I don't know man, their casting looks hella rough to me. I'd be weary of the quality of these parts.
Postby alltrac92 » Thu Aug 20, 2009 10:22 am
Cast iron does have a textured rough surface. It's obvious they have a black coating on the bracket. I guess you prefer the rust look?
alltrac92
Postby KILLA CAM » Thu Aug 20, 2009 10:43 am
If they cast a new bracket from scratch, why use the OEM dual piston?? Just get the Ericsol brackets.
The only way this would be beneficial to us is if they would cast a new bracket that would accept a 4 pot piston. Anyone know any that can be copped for the low low?? :lol: The Supra TT calipers sell for a rediculous high price! :x
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby Dawgz » Thu Aug 20, 2009 10:53 am
they look like quality casting.
that, with the dual piston setup should be perfectly fine.
Although, i dont know why you sent it in when you could just get the ericsol/trd4life bracket extension for 150?
Postby Dawgz » Thu Aug 20, 2009 10:54 am
KILLA CAM wrote:If they cast a new bracket from scratch, why use the OEM dual piston?? Just get the Ericsol brackets.
i know that TRD makes a 4 piston setup for one of the toyota trucks....
also, a few weeks ago, i met a solara owner who had a 4 piston setup as well (but off of a 350z). He made his own brackets.
ASG14 and speedysolara can tell ya more about the guy.
Users browsing this forum: Google [Bot] and 54 guests
