SolaraGuy.com • View topic - Can N E 1 help me?
Can N E 1 help me?
Can N E 1 help me?
Postby hnda8r » Tue Jul 22, 2003 6:57 am
Probably a stupid question, but what does it mean when you car is running rich? And how would you fix it? My check engine light is still on. :o
In search for my next Supercharged Solara!!!
hnda8r
Postby STR8PYP » Tue Jul 22, 2003 7:02 am
Means that there is more fuel going into the engine than normal. It's probably running rich BECAUSE of the check engine light, which is a normal response from the ECU to prevent any detonation due to lean (less fuel than nominal) fuel delivery.
SC
STR8PYP
Postby krook » Wed Jul 23, 2003 12:32 pm
RICH: too much fuel, not enough air
LEAN: too much air, not enough fuel
krook
Postby hari-bhari » Wed Jul 23, 2003 3:09 pm
STR8PYP wrote:Means that there is more fuel going into the engine than normal. It's probably running rich BECAUSE of the check engine light, which is a normal response from the ECU to prevent any detonation due to lean (less fuel than nominal) fuel delivery.
SC
wouldnt more fuel be more likely to detonate as opposed to less fuel??
hari-bhari
