SolaraGuy.com • View topic - What kinda camber kit are you useing?
Postby LEE337 » Mon Aug 24, 2009 2:26 pm
As for camber kits, which do you recomend??
Are ther some that I should not use???
Ive done some searches on here and Im still not sure which ones would be benificial.
Im lowered on Tein S-Tech's w/Monroe Sensa-Tracks
Right now I have 17" Enkei's w/205/40/17.
Im too negative, way too negative. Ive completly worn down the inside of my front tires.
I want 18's. Im leaning towards some 18" TSW's w/225/45/18 tires or should I get 225/40/18? I know I want 18s with a 225 tire.
Postby Mr_Krispy1183 » Mon Aug 24, 2009 3:22 pm
225/40/18 with your 18s would be what you'd want, as that's the closest in overall diameter to the OEM wheel/tire combination.
As for a camber kit, I have a brand new set of SPC camber bolts for the front with +/- 1.25 degrees of adjustment. PM if you're interested.
Postby LEE337 » Mon Aug 24, 2009 3:38 pm
Thanx!
Im use to seeing the camber bolts.
So how are the bolts different from these.
http://www.andysautosport.com/toyota/19 ... ts/eibach/
Are the bolts pretty much all the same?
Are there some higher quality ones out there??
By adjusting the front, will I then need to adjust the back???
I know, lots of questions but I sick of buying tires!!!
Postby LEE337 » Mon Aug 24, 2009 7:48 pm
The Discount Tire calculator is telling me that 225/45/18 is closer to OEM than 225/40/18.
Why is that?
Which tire calculator is the best on to use?
Postby GreenSolara01 » Mon Aug 24, 2009 7:49 pm
The back is a little more ajustable stock. I'm pretty sure the bolts in the pic are not for mcv-20 s at all.
I thought I would order a set of eib camber kit but my buddy's distributor told us all the camber kit for the car are exactly the same SPC Eibach all the same i got my front and back for $30
I havn't put them on yet But think ing about it now that my springs a settled in.
If you adjust the front you don't have to do the reaer but you probbaly want to square up your gemetry to halp your tires and get better traction.
GreenSolara01
Postby ThatVietGuy » Mon Aug 24, 2009 7:51 pm
LEE337 wrote:The Discount Tire calculator is telling me that 225/45/18 is closer to OEM than 225/40/18.
Why is that?
225/45 is the correct answer.
ThatVietGuy
Postby Mr_Krispy1183 » Mon Aug 24, 2009 8:00 pm
^I'll concur, I wrote 40 in haste here @ work.
Most companies offering camber bolts source them from SPC, Eibach included.
Also, you don't need to go crazy with the rear, just get it all aligned at once to square everything up.
Postby GreenSolara01 » Mon Aug 24, 2009 8:55 pm
^sounds like what I wrote. Good job crisp.
GreenSolara01
Postby TMMK Toy » Mon Sep 07, 2009 6:37 pm
Some things to think about on preserving tire life. Rotating regularly helps and toe kills tires faster than camber does.
TMMK Toy
Postby LEE337 » Mon Sep 07, 2009 6:48 pm
Thanks everyone.
Everything is gravy, except my camber. It killed my driverside front tire.
I bought some SPC Camber bolts from Brian. Thanks! :D (Mr_Krispy1183)
Im ditching the 17s and getting some 18s w/225/45 tires.
Havent decided on either TSW or Petrol wheels.
As for tires either Goodyear GT II or Falken 452s.
Users browsing this forum: No registered users and 64 guests
