SolaraGuy.com • View topic - Lower Front Brace?
Lower Front Brace?
Lower Front Brace?
Postby RON » Fri Aug 28, 2009 11:50 pm
RON
Postby ThatVietGuy » Fri Aug 28, 2009 11:58 pm
ThatVietGuy
Postby 99BlackSandv6 » Sat Aug 29, 2009 1:41 am
^ what he said
Postby RON » Sat Aug 29, 2009 1:45 am
Yeah
Just went to the thread. What's the feedback so far?
RON
Postby 99BlackSandv6 » Sat Aug 29, 2009 1:52 am
All positive as far as I know. Only thing you lose is a little ground clearance and a couple bucks. But all in all it has good reviews.
Postby RON » Sat Aug 29, 2009 1:57 am
99BlackSandv6 wrote:All positive as far as I know. Only thing you lose is a little ground clearance and a couple bucks. But all in all it has good reviews.
Thanks...
Yeah...clearance (with the front) is an *issue*..I'm only 1.5 lower in front though. I think the original poster was lower?
RON
Postby trd4life » Sat Aug 29, 2009 9:51 am
My bar is completely destroyed from hitting the ground and i am only lowered on tein s tech springs .
Postby Mr_Krispy1183 » Sat Aug 29, 2009 10:18 am
^Gabe, seriously? Can you post pics of it? I'm curious.
As for mine, I've had it in ever since, and aside from the occasional scrape on steep speedbumps and such, the bar's been doing great. The only spots even hitting/scraping are the mounting point lips that protrude downward. My bar is still completely intact.
Postby TRDSleeper » Sat Aug 29, 2009 10:56 am
Yeah, the ground clearance in the front can sometimes be a pain. I'm only lowered on Eibach springs and one in awhile I'll scrap it on a speed bump if I don't go straight over it. Then when I took the car to my mechanic for a wheel alignment it actually couldn't clear the ramps on his hydraulic lift. He was driving it up slowly until I heard...BAMMM! And the car bounced back a bit. I don't know what it hit exactly but the bar got dented slightly at the mounting hole. Good thing I didn't damage his lift, haha.
TRDSleeper
Postby 99BlackSandv6 » Sat Aug 29, 2009 12:41 pm
Hey man if he was driving the car onto his lift he should check under the car before hand to make sure everything will clear, I say it would be his fault. But you also wouldn't want to damage a friends expensive lift.
Postby ptballer » Sun Aug 30, 2009 10:06 am
If you're on coils you will not be able to clear speed bumps.
ptballer
Postby indiglosolara » Sun Aug 30, 2009 10:48 am
Great product... but not if you are low like i am... my front trd kit lips are only 2" off the ground at the lowest point.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby RON » Sun Aug 30, 2009 12:57 pm
indiglosolara wrote:Great product... but not if you are low like i am... my front trd kit lips are only 2" off the ground at the lowest point.
I'm around 1.5" lowered...what do you guys think?
RON
Postby t3chnique » Sun Aug 30, 2009 3:32 pm
hey ron, measure for us how high the lowest part of your kit is from the ground.
t3chnique
Postby RON » Sun Aug 30, 2009 3:41 pm
t3chnique wrote:hey ron, measure for us how high the lowest part of your kit is from the ground.
I like to use this measurement..
Distance from edge of front fender (right above the tire) to the center of the wheel (center of wheel cap). You can be very accurate with this and it's very SPECIFIC for comparisons. However, it doesn't take into consideration any mods (exhaust) that may be hanging below the car. For this measurement, Stock is around 15 1/2" and my car is around 14.25". What's your measurement?
Thanks
RON
