SolaraGuy.com • View topic - Fumoto valve is leaking. Need help.
Postby MountainDude » Sun Aug 30, 2009 5:08 pm
Hi all.
I installed the Fumoto valve on my 2001 SE V6, but it leaks around its gasket. I have bought two types of gaskets from AutoZone, one is metal (Aluminum) and the other plastic (white).
Has anyone successfully installed a Fumoto? Which gasket did you use?
Any help is appreciated.
Thanks.
MountainDude
Postby Inverted » Sun Aug 30, 2009 5:35 pm
If it's failing I'd say go back to a regular oilpan bolt and call it a day. Good thing you noticed the leak!
Inverted
