SolaraGuy.com • View topic - What Does it Take? 1mz/ 3mz Hybrid
Postby 99BlackSandv6 » Sun Aug 30, 2009 10:21 pm
So what exactly does it take to do a 1mz/ 3mz hybrid? Other than the obvious short block swap, what other mods are needed to pull off this swap? I know only a few guys have done it and I could have done some PMs but I figured I would put this as an open thread to help anybody interested in doing this.
Help me out experts! What does it take? :)
Thanks in advance,
Ben
Postby jetbtkng » Sun Aug 30, 2009 10:25 pm
money, money, and more money, lol............................... :drinking:
Postby 99BlackSandv6 » Sun Aug 30, 2009 10:27 pm
Not a lot if parts and labor are free :D
Postby ~SolaRaSpeed~ » Sun Aug 30, 2009 11:31 pm
i think PMs are in order if you really want to know, although it would be nice to have the basic info available in a thread that most likely no one will search for...
~SolaRaSpeed~
Postby jetbtkng » Mon Aug 31, 2009 12:26 am
list of goodies, block, pistons, rods, crank, heads, and you'll want to port & polish them, supercharger, injectors, gasket kit, plugs, plug wires, safc, cai, oil, fuel pump,jims fuel mod, jims torque rod, now some of that stuff comes with the hybrid, talk to gabe, greg, tracy, im sure i forgot some stuff....................... :drinking:
Postby Inverted » Mon Aug 31, 2009 5:15 am
What is the purpose of said hybrid?
Inverted
Postby trd4life » Mon Aug 31, 2009 9:22 am
more displacement and higher compression ratio
Postby 99BlackSandv6 » Mon Aug 31, 2009 11:48 am
Yeah, as the old addage goes, "There is no replacement for displacement." although boost is also considered to be the great equalizer. Basically, I am going to keep this car as long as I can, and my thinking is that if I can put a new block in it and freshen up the engine, while also getting a little more power, that would be beneficial to my 500,000 mile goal. Plus I have a possible source for cheap short blocks with ZERO miles, and it would be a Sweet mod. I would like to make a healthy amount of NA hp and I need displacement to do that. It was just an idea.
What does the Comp. Ratio get bumped to, 1mz is 10.5/ 1 is this going to make the hybrid more like 11-11.5/ 1?
Postby Inverted » Mon Aug 31, 2009 11:57 am
Right... so why not just do a straight 3mz swap? Are there parts on the 1mz that are better?
Inverted
Postby trd4life » Mon Aug 31, 2009 11:59 am
3mz is vvt-i so in order to do the full swap lots of wiring not only that but the 3mz also uses a Drive by wire throttle which makes the swap even more difficult, and with a full 3mz swap you cant trd s/c it.
Postby 99BlackSandv6 » Mon Aug 31, 2009 12:11 pm
^Yeah, what Gabe said :)
Postby Inverted » Mon Aug 31, 2009 12:25 pm
http://enginespro.com/2004-toyota-camry ... p-305.html
So would that do the trick? Expensive but not as bad as I thought...
Inverted
Postby 99BlackSandv6 » Mon Aug 31, 2009 12:38 pm
Inverted, all you need is the short block, meaning everything below the heads. Gabe PM'd me and said that all it takes is the 3mz short black, and head gaskets, and some machining to reroute the oil from the block to work with the 1mz heads. Its simple stuff really, he said he can mod the block and have it ready to swap for about $1400.
Postby Inverted » Mon Aug 31, 2009 12:46 pm
That's not bad at all... I can definitely see the draw to doing this now. Would want to use higher than 87 octane to run this I presume?
Inverted
Postby Mr_Krispy1183 » Mon Aug 31, 2009 1:13 pm
^Umm, yeah. 91 minimum.
Users browsing this forum: Google [Bot] and 54 guests
