SolaraGuy.com • View topic - 2GR-FE?
2GR-FE?
2GR-FE?
Postby Gibson99 » Tue Sep 01, 2009 10:06 am
anyone contemplated putting this motor in a camry/solara? 3.5L found in avalon, sienna, etc. VERY peppy in the avalon... i'm thinking i wouldn't mind one in the camry if something fatal were to happen to my 1mz...
Gibson99
Postby SleeperSolara » Tue Sep 01, 2009 10:51 am
I was thinkin' about that.....
That would be interestin'.
I was thinkin' if the 3MZ bottom works wit the non-VVTi 1MZ heads, the 3MZ bottom end should work wit the 1MZ heads wit VVTi??
That would be interestin' wit a 3MZ bottom end and 1MZ VVTi heads.
Postby 99BlackSandv6 » Tue Sep 01, 2009 10:54 am
Might be cool, I'd rather have the 1mz/ 3mz though.
Postby ASG14 » Tue Sep 01, 2009 11:25 am
They are ploping them into the MR2 mated to the E153. So yeah, it should Def work out. But still won;t be as simple as dropping it in and driving off.
ASG14
Postby Gibson99 » Tue Sep 01, 2009 11:30 am
i figured it wouldn't be a plug n play affair, since all of them will be immobilizer/transponder keys (though that could bring pushbutton start... heh) and none of them are stick.
and we mustn't forget that the 2gr-fe is an interference engine. of course, so is the 3mz...
Gibson99
Postby onefiend » Tue Sep 01, 2009 1:06 pm
Seeing a Solara with a 2GR swap would be very unique and expensive.
I didn't know the 2GR was an interference engine, good thing it comes with a timing chain.
onefiend
Postby Jakecallun20 » Tue Sep 01, 2009 2:40 pm
Not to mention the oil line recall on the 2GRs.....but they are very quick in the SE camry.
Postby onefiend » Tue Sep 01, 2009 3:51 pm
Jakecallun20 wrote:Not to mention the oil line recall on the 2GRs.....but they are very quick in the SE camry.
There's no recall, just a TSB for the 05-06 Avalon. But late 09 and 2010 Camry models already have the all-metal pipe instead of the rubber-metal pipe found on 07's to early 09's. I had mine replaced to the all-metal pipe for preventative maintenance before I experienced this oil leak 8)
onefiend
Postby SleeperSolara » Wed Sep 02, 2009 6:11 am
Gibson99 wrote:i figured it wouldn't be a plug n play affair, since all of them will be immobilizer/transponder keys (though that could bring pushbutton start... heh) and none of them are stick.
What do you mean by interefernce engine??
Neva heard that term......
I just google'd it, and still confused about it.....
2gr
Postby Gregtrd » Wed Sep 02, 2009 8:46 am
Long story short if the timing chain were to snap the valve and pistons will crash into each other.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby Black Bob » Wed Sep 02, 2009 11:18 am
^^^Mostly a Honda term....
Black Bob
Re: 2GR-FE?
Postby JMSinMaryland » Wed Sep 02, 2009 12:21 pm
Gibson99 wrote:anyone contemplated putting this motor in a camry/solara? 3.5L found in avalon, sienna, etc. VERY peppy in the avalon... i'm thinking i wouldn't mind one in the camry if something fatal were to happen to my 1mz...
Holy Molly, back from the dead!!! LONG time since Camryman.org :D
JMSinMaryland
Re: 2gr
Postby SleeperSolara » Wed Sep 02, 2009 9:59 pm
I see. :o
Thanks for the information.
Postby 99V6solaraSE » Tue Sep 15, 2009 1:20 am
99V6solaraSE
Postby Midias » Tue Sep 15, 2009 3:51 am
99V6solaraSE wrote:http://www.toymods.net/forums/showthread.php?t=43884
Holy crap :o
