SolaraGuy.com • View topic - thanks everyone, but FEW more questions...really sorry =D
Postby wannaupgradesolarabad » Tue Jul 22, 2003 9:28 pm
Ok so here is what i think i'm gonna go with on my car:
Pro1's 9006 Fog
Blue Domelight
Pretty sure the Xerd CAI (u guys rock for leading me to that)
Tokico Shocks
But here are my questions:
(this is prolly a dumb question) what exactly do struts do and should I get them? if so, which are best? Same questions for shocks as well.
I need more responsive brakes...what should I get replaced/upgraded and which manufacturer?
Thanks again
Postby Mole » Tue Jul 22, 2003 9:32 pm
well for brakes, there is a Rotora big brake upgrade GB list that is going on over at teamsc3.com (13.2 disc with 4 piston)
Struts are what absorbs the road inperfections. ie bumps dips etc. tokicos are the only aftermarket ones out for solaras that are able to handle the lowerings.
Postby wannaupgradesolarabad » Tue Jul 22, 2003 9:41 pm
well, i don't wanna lower them i jus need shocks that are smoother b/c my rims make the ride pretty bumpy =/ So should i jus stick to the stock springs?
Postby wannaupgradesolarabad » Tue Jul 22, 2003 10:35 pm
also, will replacing brakes interfere w/ my abs? or is that something TOTALLY diff?
Postby hari-bhari » Wed Jul 23, 2003 5:34 am
wannaupgradesolarabad wrote:well, i don't wanna lower them i jus need shocks that are smoother b/c my rims make the ride pretty bumpy =/ So should i jus stick to the stock springs?
how big are your rims? most of the time ull want to lower the car after getting rims. the part that does the actual lowering are the eibach springs, they make your car sit lower. however, using the springs in conjunction with the stock struts will give you poor ride quality, because the gas inside will be compressed beyonds its normal level already, leading to less absorption of bumps and a bouncy ride. that is why people recommend the tokico struts at the same time you get your lowering springs, so there is minimal sacrifice in ride quality, and you dont have to pay for installation again when you blow your OEM struts.
hari-bhari
Postby SammySolara » Wed Jul 23, 2003 7:03 am
Hey! wannaupgradesolarabad, don't be sorry for your questions... that's what we are here for-- to help out other Solara owners :P.
Oh, by the way: Sign up and you can have tons more fun :wink:
Jen `02 Solara
"Theres no law for how fast you get to the posted speed limit"
<img src="http://free.inkfrog.com/pix/sammysolara/HQ162.jpg">
SammySolara
Postby WTF?? » Wed Jul 23, 2003 7:47 am
In order for you to stick to the "comfortable ride" stay with the stock shocks and springs... the reason being is that theyre softer for the luxury ride and not performance... upgrading to tokico gas shocks will give you a stiffer ride which will lead to more handling... do more research into the tires/rims/tire pressure and youll even get more comfort
sumone wanna back me up on this?
Retired... its been fun Image
WTF??
Postby TXSolaraSLE » Wed Jul 23, 2003 8:12 am
solara nytez wrote:In order for you to stick to the "comfortable ride" stay with the stock shocks and springs...
like solara nytez said, you're not going to find a more "comfortable" ride with aftermarket parts, because they're all designed for performance. performance = stiffer springs = less "comfortable" ride quality. From what you've said, it sounds like the only reason you would need to spend any money on suspension is if your struts are bad and need to be replaced. as for the rest of your stuff, there's lots already posted if you use the search function
'99 Black Solara SLE
18" Mille Miglia Evo5
Yokohama AVS ES100
Indiglo Gauges
Kicker KSR100
K&N Filter
Xenon Headlights & License plate bulbs
TXSolaraSLE
Postby mlimin » Wed Jul 23, 2003 9:13 am
for the big brake kit you will have to find the right offset wheel. I got brembo big brake kit, and it just pain in the... to find the right offset. I ends up sell my tsw rims and get racing hart just to fit that giant brake. Even with the new wheel I still need to add 5 mm spacer, but the brake really make big difference.
mlimin
Postby wannaupgradesolarabad » Wed Jul 23, 2003 9:59 am
my rims are 17" trd's...the red capped rims.
Postby Guest » Wed Jul 23, 2003 10:01 am
mlimin wrote:for the big brake kit you will have to find the right offset wheel. I got brembo big brake kit, and it just pain in the... to find the right offset. I ends up sell my tsw rims and get racing hart just to fit that giant brake. Even with the new wheel I still need to add 5 mm spacer, but the brake really make big difference.
how can u figure that out?
Guest
Postby WTF?? » Wed Jul 23, 2003 10:02 am
u got the trd rims... but didnt lower the car and still want a more comfy ride?
Am i the only one whos confused?!? :crazyeyes:
WTF??
Postby Guest » Wed Jul 23, 2003 10:24 am
solara nytez wrote:u got the trd rims... but didnt lower the car and still want a more comfy ride?
haha, sorry...I bought this car used w/ the rims so the former owner MITE have lowered it, but it looks about level w/ stock solara's i've seen. Anyways, if the stock shocks are the comfiest option i'll stick w/ those. So i guess my only real question is what brakes are really worth it.
Guest
Postby xXsolaraXx » Wed Jul 23, 2003 12:01 pm
TRDMole177 wrote:well for brakes, there is a Rotora big brake upgrade GB list that is going on over at teamsc3.com (13.2 disc with 4 piston)
by the way KYB also make struts for the solara! 8)
xXsolaraXx
Postby impactX » Wed Jul 23, 2003 12:22 pm
IMO, Bilstein > Tokico > KYB (non AGX)
impactX
