SolaraGuy.com • View topic - hid
hid
hid
Postby MiistahSaan » Wed Sep 23, 2009 4:08 pm
well, i had 8000k hid for a 2000 solara. i believe it was h4 bulb but it was only low beam. i just recently ordered h4 bulbs and now i seem to be only gettin the hi beam. do anyone know how to fix this? or should just stop wasting my time and buy a whole new kit
MiistahSaan
Postby ThatVietGuy » Wed Sep 23, 2009 4:56 pm
Do you mean that you can only get the bulb to turn on with you flick the column for the high beam?
ThatVietGuy
Postby kenny6683 » Wed Sep 23, 2009 6:37 pm
on my HID the regular low beam is the bright bulb that is powered by the ballast and the high beam is this small h3 or h4 bulb which is useless. i didnt even bother to connect it because switching over from low beam to high beam just gets dimmer lol
kenny6683
Postby krook » Wed Sep 23, 2009 7:53 pm
did you wire it up correctly? or is this a "plug-'n-play" kit?? From the driver's side harness, the Red/Yellow should be H4(low beam), and the Red should be your High beam. The 2 Red/Black wires should be Ground.
krook
Postby MiistahSaan » Thu Sep 24, 2009 10:11 pm
nvm. figured it out. the polarity was differnt, i just had to plug the wire into the ballast the oppsite way. loL! thx anywaise
MiistahSaan
Users browsing this forum: Google [Bot] and 46 guests
