SolaraGuy.com • View topic - Brake up grade
Which do you choose??
Drill & Slotted No name
0
No votes
Drilled only by Brembo's
6
100%
Total votes : 6
Brake up grade
Brake up grade
Postby indiglosolara » Wed Jul 23, 2003 10:12 pm
Hey wasup,
I am planning to get new brake rotors in the front and planning change to drill and sloted rotors but can't decide on which one to get..also another question is i have the i-4 and these say its for the v6. will these fit???
1. I dont know the company name but heres the link:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2424808678
2. these are the brembo. these are only drilled and not slotted:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2424333461
Which do u think i should get if they fit...
Thanks Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Mole » Thu Jul 24, 2003 12:53 am
hey kenny, get into that Rotora GB :) on teamsc3.com
Postby TadS » Thu Jul 24, 2003 6:15 am
Get the brand name for sure :) . Also, I would make sure that this place isn't just drilling OE style blanks vs. real cross drilled Brembos, which can be seen here. http://www.coximport.com/store/35358 I think the front rotors are the same. Cox Import list the Part#'s as being the same for the fronts on both cars at least.
TadS
Postby indiglosolara » Thu Jul 24, 2003 9:13 am
Thanks i will look into the GB in sc3
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Brand Name... but a suggestion
Postby mosch » Thu Jul 24, 2003 11:22 am
If you're planning to track your car, get slotted, not drilled. After you've raced for a while you'll find small cracks radiating toward the outside of your brakes if you use drilled brakes.
01 Solara SE V6
mosch
