SolaraGuy.com • View topic - LOUD injectors
LOUD injectors
LOUD injectors
Postby NRDriver » Mon Oct 05, 2009 6:19 pm
i dont know if i will get anything usefull outta this post but i will ask anyways.
My injectors are ticking loud ass all heck. i know ticking from the injectors isnt uncommon but my car use to purr and now it just ticks. lol. yes i know it is the injectors(before you ask). I just did headgaskets on it and checked all valve clearances, all good. i can unplug an injector and here it go away. i took a stethascope to all of the injectors and it is definately them. i can even feel it when i put my finger on the injectors.
question is.... has anyone else had this problem. it seems like it gets louder as time goes on.
FYI. i do drive it like I stole it. i have hks ignition, 3" CAI, Jet chip, Datsrpipe, greddy exhaust, etc.
NRDriver
Re: LOUD injectors
Postby Dawgz » Mon Oct 05, 2009 6:26 pm
NRDriver wrote:i dont know if i will get anything usefull outta this post but i will ask anyways.
My only suggestion would be to send one or all of them in actually so http://www.witchhunter.com/ to have then tested and cleaned it they already have not been?
My injectors came with a sheet of how they performed when they got them, and how they performed once they were cleaned,etc.
That data table could help you solve any issues?
clean
Postby NRDriver » Mon Oct 05, 2009 6:42 pm
i might have done that accept for all the injectors are evenly loud. i did forget to say that i have a 190lb fuel pump and i am naturally aspirated.
NRDriver
Postby Dawgz » Mon Oct 05, 2009 6:43 pm
are these stock injectors btw?
stock
Postby NRDriver » Mon Oct 05, 2009 6:58 pm
i believe so. the problem is.... i bought the car used. it had an ignition system on it and i believe it had a supercharger before i bought it. it also had a jet chip in it which i didnt find out about till about 6 months ago. everytime i work on it i find some new mod that was done to it. i am gonna get the part number off them and see
NRDriver
Postby JavaJoe_2 » Mon Oct 05, 2009 7:25 pm
Are you sure the tick is the injectors and not the valves?
Got Boost?? :sweet:
JavaJoe_2
Re: LOUD injectors
Postby gnegroni » Mon Oct 05, 2009 7:44 pm
Dawgz wrote:My only suggestion would be to send one or all of them in actually so http://www.witchhunter.com/ to have then tested and cleaned it they already have not been?
So how much did your before and after results vary?
gnegroni
Postby jetbtkng » Mon Oct 05, 2009 8:24 pm
throw in a couple of bottles of injector cleaner, one stp & gunk together, fill it up and drive it until you need to fill up, and see if that quiets them down................... :drinking:
Postby 99BlackSandv6 » Mon Oct 05, 2009 8:35 pm
Ignore the ticking, it's normal. I would say that the combo of
the 190 + JETchip = faster/ harsher opening of the injectors
and therefore louder injectors.
Postby akora12 » Tue Oct 06, 2009 9:25 am
^I'll have to disagree. Many of us are flowing much more fuel w/o ticking problems.
My supra injectors sound like stock, but I had them cleaned by witchhunter and fit with stock o-rings before installing them.
Users browsing this forum: Google [Bot] and 46 guests
