SolaraGuy.com • View topic - big brake. will this fit?
Postby AkoSiHarold » Mon Oct 05, 2009 8:51 pm
hey SG. got a quick question for you guys. i recently found a front brembo breke calipers that came from a mitsubishi evo 8 up for sale. so i was wondering if anyone know if it will fit the solara?
AkoSiHarold
Postby ThatVietGuy » Mon Oct 05, 2009 8:53 pm
You'll probably have to machine custom mounts to be able to use the OEM mounting points.
In other words, no, you probably can't expect the calipers to fit the car AS IS.
ThatVietGuy
Postby CamryOnBronze » Tue Oct 06, 2009 7:13 am
Agreed. There is always a chance they will fit, but you will most likely need larger rotors and a custom brake bracket.
Since the Solara is 5x114.3, you could probably use those calipers in conjunction with Evo rotors, which are 13" and the same bolt pattern. People retrofit these brakes onto 240s all of the time by using a custom bracket.
You will also have to consider if the rear caliper has a built in e-brake setup or not- if not, you will have to rig something up to make the e-brake work.
Postby gnegroni » Tue Oct 06, 2009 8:34 am
CamryOnBronze wrote:Agreed. There is always a chance they will fit, but you will most likely need larger rotors and a custom brake bracket.
Is the Gen2 5 x 114.3 by any chance...meaning Gen1-1.5 upgrades could work for us too?
gnegroni
Postby CamryOnBronze » Tue Oct 06, 2009 10:41 am
I think the gen 2 is 5x114.3, yes. Don't people put gen 2 wheels on the gen 1?
Milt had a Stoptech kit on Posh's solara (gen 2), so yes- they would fit.
Postby gnegroni » Tue Oct 06, 2009 2:56 pm
CamryOnBronze wrote:I think the gen 2 is 5x114.3, yes. Don't people put gen 2 wheels on the gen 1?
That is freaking awesome...that means I could use the Supra Rotor kit...woohoo!
Thanks!
gnegroni
Postby AkoSiHarold » Wed Oct 07, 2009 12:06 am
ic. how about a supra calipers? man, i might just go es300 calipers w/ trd4lyf bracket and 13" supra rotor.
AkoSiHarold
Postby Mr_Krispy1183 » Wed Oct 07, 2009 6:54 am
^Probably the better choice, as Gabe already has that option ready and for sale.
Postby SleeperSolara » Wed Oct 07, 2009 9:29 am
I found 2 more twin piston calipers at the yard, will be back there later this afternoon to pick them off. :D
Postby CamryOnBronze » Wed Oct 07, 2009 1:15 pm
If I were swapping to another oem caliper that is so common like the ES, I would just buy reman ones from Autozone or something IMO. I did the Q45 brake upgrade on my 240 and got the 2 piston calipers from autozone for something like $120 after core. That way you know it has been rebuilt and you don't have to go through the trouble yourself... just my two cents.
Postby SleeperSolara » Wed Oct 07, 2009 11:15 pm
CamryOnBronze wrote:If I were swapping to another oem caliper that is so common like the ES, I would just buy reman ones from Autozone or something IMO. I did the Q45 brake upgrade on my 240 and got the 2 piston calipers from autozone for something like $120 after core. That way you know it has been rebuilt and you don't have to go through the trouble yourself... just my two cents.
That's true but at $120 for just one.
You can buy 2 from me and rebuild them yourself, and learn in the process of how to rebuild some calipers.
From me you can buy 2 twin piston calipers that are either Gen 3 or ES300 for about $60.
Price may go up since they are chargin' me differently..... :-?
Postby CamryOnBronze » Thu Oct 08, 2009 1:20 pm
Ah, I got both for $120 (combined).
Postby ---CAMRAZY--- » Thu Oct 08, 2009 11:34 pm
Supra rotor with the OG Ericsol bracket will not work. I had tried it about 3-4 years ago on Posh's gen2....
Postby gnegroni » Fri Oct 09, 2009 5:37 pm
---CAMRAZY--- wrote:Supra rotor with the OG Ericsol bracket will not work. I had tried it about 3-4 years ago on Posh's gen2....
Then no similar upgrade works on Gen2? Is it something to do with the hub or disc?
gnegroni
Re: big brake. will this fit?
Postby gabe74gt » Mon Oct 26, 2009 11:01 am
AkoSiHarold wrote:hey SG. got a quick question for you guys. i recently found a front brembo breke calipers that came from a mitsubishi evo 8 up for sale. so i was wondering if anyone know if it will fit the solara?
I have already tried to my car in earlier but, it has not matched with my car, as the calipers pad are occupying more area and taking more time to operate. so don't go for that.
gabe74gt
