SolaraGuy.com • View topic - headers
headers
headers
Postby thenewguy » Tue Oct 27, 2009 8:37 am
now i was given this website for headers and i have a question..
http://jpheadersexhaust.com/cgi-bin/jpp ... ota+Header
Is there some headers i can get without the high flow cat.? Because i wanna be able to pass the smog test everyyear with the hassle of putting on and taking it off.
Thanks :bday:
thenewguy
Postby SleeperSolara » Tue Oct 27, 2009 9:34 am
Wit the high flow cat you should be able to pass smog, I think.
Postby Chinky420 » Tue Oct 27, 2009 9:38 am
you may want to check out OBX product line up before you commit to buying the jpp set.
the OBX exhaust set was modeled after the jpp, IIRC.
i don't know if you're NA or boosted, or if you're looking for just headers or a full exhaust system, but for the price difference, it's worth considering the OBX.
Chinky420
Postby Midias » Sun Nov 01, 2009 8:26 am
SleeperSolara wrote:Wit the high flow cat you should be able to pass smog, I think.
Not with the Jpp cat from what I remember. It needs an o2 sim or some antifoulers so it may not pass the sniffer.
You have three header choices
Jpp
OBX
Ebay china special.
Postby Mole » Sun Nov 01, 2009 9:34 am
did anyone pass with aftermarket headers and normal cat ?
i assume just with aftmkt headers alone will already fail.
Postby campfire9 » Sun Nov 01, 2009 10:32 am
I have a 99 v6 California Solara with aftermarket headers from ebay. I still use my 99 Solara cat and have never failed a California smog test. I also have a CPE intake and throttle body spacer. Never failed. This year I'll have to find another checker because the place I always used is under construction.
The trick is to have a visual inspection first and if they don't say that you are not legal then you should be good to go. The generally ask for the suppliers decal to indicate it is California legal. If they don't like what you have then go to another location.
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby Mole » Sun Nov 01, 2009 11:50 am
is the rest of your exhaust stock?
I had a custom Y pipe and could't pass if my life depended on it.
Postby campfire9 » Sun Nov 01, 2009 3:44 pm
I have custom y pipe. Each pipe at the lower end of the headers run parallel for a short way then into a true Y to the single pipe. The rest of my exhaust is stock. No problems.
Thanks to whomever fixed my replies. I tried to use the X on one reply and I still couldn't delete. As for my original reply, I couldn't find any way to delete it.
campfire9
Postby RON » Sun Nov 01, 2009 4:06 pm
Mole wrote:is the rest of your exhaust stock?
I live in Burbank and just past with SC..Custom Y pipe..Injen Ram. Never had a problem as far as *visuals* go. I do have stickers for SC and Injen. Nothing on Y pipe though, but it's not conspicuous either. :D
RON
Postby CamryOnBronze » Mon Nov 02, 2009 9:13 am
Just to be clear, OBX is usually lumped into the "Ebay China special" in most car communities (SG excluded, it seems.) :lol:
Postby Gibson99 » Mon Nov 02, 2009 11:24 am
i have the JP headers without a cat. i added an o2 sim and now it passes. or it will next time i go in, since Texas doesn't do visuals like they do in the Peoples Republik of Kalifornia. :P
Gibson99
