SolaraGuy.com • View topic - Auto trans cooler install picts.
Postby Midias » Fri Oct 30, 2009 2:13 pm
I am not digging the auto trans cooler on my wife's aftermarket radiator. So I bought an auto trans cooler it is coming in the mail soon. So post you pics of where you have mounted yours.
Postby SleeperSolara » Sat Oct 31, 2009 12:54 am
I'll be gettin' a bigger one soon.
But here's where mine is:
Postby drewcrane » Sat Oct 31, 2009 7:42 am
i installed a trans cooler as well as an oil cooler on my challenger and i did notice a big difference in engine tem p, also be sure to mount it in a place that doesnt block airflow to the radiator,
i tried 2 different locations until i found good cooling for all coolers, i also made different brackets so i could move it around for max cooling,recently i did have a situation where it was to cool and i used a piece of cardboard to block it off,until it warmed up the out side temp was 28 degrees,
but these coolers do work quite well, i have found alot of different styles at salvage yards ,and actually found a heavy duty unit from a bus and it works rather well!
"its a vanishing point thing you wont understand"
drewcrane
Location: 13.7 sec.s @bandimere ,5800 ft above sea level
Postby SleeperSolara » Sat Oct 31, 2009 10:49 am
drewcrane wrote:i installed a trans cooler as well as an oil cooler on my challenger and i did notice a big difference in engine tem p, also be sure to mount it in a place that doesnt block airflow to the radiator,
Yeah i was thinkin' about gettin' one from a truck.
Postby lexmex » Sat Oct 31, 2009 1:12 pm
My RX300 has a factory trans cooler, the part number being 32910-48010, but it's like $500 from the dealer.
lexmex
Postby Dawgz » Sat Oct 31, 2009 1:16 pm
lexmex wrote:My RX300 has a factory trans cooler, the part number being 32910-48010, but it's like $500 from the dealer.
im pretty sure all automatics come with a factory trans cooler.
Postby bbq bob » Sat Oct 31, 2009 2:20 pm
summit racing has trans. coolers . from cheap to high dollar. frank got one thats big for about 27 bucks. they also have trans and oil cooler combo all in one .
bbq bob
Postby JavaJoe_2 » Sat Oct 31, 2009 3:23 pm
Here's the setup on my old Camry.
Originally it was from TRD for the Tacoma.
Got Boost?? :sweet:
JavaJoe_2
Postby WUTANGCLAN » Sun Nov 01, 2009 6:29 pm
how easy is it to install a trans cooler?
WUTANGCLAN
Postby Solarizona » Sun Nov 01, 2009 6:32 pm
Solarizona
Postby Dawgz » Sun Nov 01, 2009 6:39 pm
WUTANGCLAN wrote:how easy is it to install a trans cooler?
Pretty simple, take off the two tubes from the trans cooler lines, install the new ones (use a clamp as well)....run it to the area where u want to install the new cooler, mount the new cooler and connect the lines. Add just a bit of more fluid to compensate and ur good to go.
Postby SleeperSolara » Sun Nov 01, 2009 11:56 pm
bbq bob wrote:summit racing has trans. coolers . from cheap to high dollar. frank got one thats big for about 27 bucks. they also have trans and oil cooler combo all in one .
Yeah i was goin' to go to Advance Auto Parts, cause they have a bigger unit for $30.00, that i was goin' to upgrade my current one, and redo the mountin' for it.
Postby WUTANGCLAN » Mon Nov 02, 2009 10:00 am
Thanks Dawgz has anyone had good expreience with B & M tranny coolers?
WUTANGCLAN
Postby bbq bob » Mon Nov 02, 2009 8:17 pm
i ran a b & m on my 70 el camino with a 350 turbo trans. , worked real good.
bbq bob
Postby Midias » Sun Nov 08, 2009 6:45 pm
The new cooler is installed and the old is blocked off thanks guys.
