SolaraGuy.com • View topic - autometer gauges
autometer gauges
autometer gauges
Postby guest » Sun Jul 27, 2003 9:38 am
I just got my dual gauge pod. . .i m thinkin about puttin in a volts gauge and an oil pressure gauge . . think these will be very easy to install? Furthermore, how would i go about installin them?
guest
Postby Yanks0114 » Sun Jul 27, 2003 9:41 am
I voltage gauge would be very easy to install but I am not sure about oil pressure.
Overall the gauge pod is pretty easy to install also
Postby SC V6 » Sun Jul 27, 2003 9:45 am
oil pressure is a b$tch.... I went to put mine in... adn the aftermarket sending unit for the Eletronic, wouldn't fit... so I put the stock one back in, I had the car jacked up so I wouldn't lose oil.. and stripped the F%ucker... its a tempered thread.. and remember, its an aluminum block
SC V6
Postby guest » Sun Jul 27, 2003 10:37 am
if the oil pressure is such a pain then is there any other gauges i should consider for the pod . . . its mainly for looks so a first thoguht about an a/f gague but was disuaded after reading prevcieous posts. . . should i reconsider the air fuel gauge or look for sumthing else?
guest
guest
Postby Mole » Sun Jul 27, 2003 5:36 pm
go for a pyrometer.
Postby Turbosolara » Sun Jul 27, 2003 6:37 pm
If his car doesnt has force induction, the EGT would not move much (maybe from 1000-3000max).
Is your car 4 banger or v6?
Postby Mole » Sun Jul 27, 2003 8:09 pm
but he's getting them for looks...
Postby guest » Mon Jul 28, 2003 6:17 am
yea i gotta six . . scot you ever get the oil gauge installed or you just forget about it . . do you think its possible to install . . well any suggestions would be greatly appreciated. . thanks
guest
