SolaraGuy.com • View topic - H.I.D In 99 Solara fogs
Postby kwan » Wed Nov 04, 2009 2:23 pm
hi everyone i am new to the site and a new and proud owner of a white 1999 sle v6 solara, i have picked up a set of 9006 hid kit for the fogs, when i had my 94 integra gsr they were 9006 as well and it was just a direct plug and play, but when i tried installing the 9006 hids into the fogs of the solara it didnt even turn on, i left the stock 9006 bulb in the other fog and it turned on but the hid didnt, is there something that i am doing wrong or is it something i am missing or is it some modifications i have to do?? if anyone could help me out here that would be great and i could post pics after
thank you fellow solara owners for your time
kwan
Postby ThatVietGuy » Wed Nov 04, 2009 3:24 pm
Try swapping the connections to the ballast on the bulbs.
ThatVietGuy
Postby LEE337 » Wed Nov 04, 2009 4:35 pm
So, you you redirected the stock plug into the ballast and hooked up your bulbs right???
Check you power wire into the ballast to make sure its not in backwards. (I did that when I first hooked mine up)
Postby kwan » Wed Nov 04, 2009 6:20 pm
hey thanks for the help guys i appreciate it, i definitly will give it a try and let you guys know how it works out
kwan
Re: H.I.D In 99 Solara fogs
Postby GzNutz » Thu Nov 05, 2009 6:27 am
kwan wrote:but when i tried installing the 9006 hids into the fogs of the solara it didnt even turn on, i left the stock 9006 bulb in the other fog and it turned on but the hid didnt
Did you have both ballasts hooked up at the same time?
Postby YESCA » Thu Nov 05, 2009 10:55 am
Toyota is backwards from honda in their wiring. I had a Civics 9006 HID's on my Solara's fog lights and the same thing happened to me. You will have to reverse the plug that goes into the ballast. you will need to give it a loving nudge for it to click in, but after that it should work no problem.
YESCA
Postby Chinky420 » Thu Nov 05, 2009 1:15 pm
go introduce yourself in the intro section.
Chinky420
Postby kwan » Thu Nov 05, 2009 8:46 pm
thanks guys for the help i am going to try it again this weekend i will take pictures and let you guy see the results, i really appreciate it 8)
kwan
Postby kwan » Sat Nov 07, 2009 4:12 pm
hey guys thanks for help it worked out with the hids in the fogs, i got some pics but they are from my crappy iphone but ill get updated pics later. :drinking: thanks again for your time
kwan
Postby 99TOYs » Thu Mar 04, 2010 11:14 pm
what color ('K') are your headlights and fogs? look great!
99TOYs
Postby kwan » Mon Mar 15, 2010 1:28 am
12000k beamers for lowbeam
6000k eagles for fog lights
kwan
Postby Mole » Mon Mar 15, 2010 1:31 am
12k K should be "black light" color.
looks more like 6k K and 4k K in the picture
