SolaraGuy.com • View topic - HID Problem.
HID Problem.
HID Problem.
Postby kteng » Sat Nov 07, 2009 4:33 pm
Hello guys:
I have a problem when i finish installed HID i bought from ebay today. Both HID, fog lights, left turn signal light are working with no problem, but right turn signal light doesn't light up along with others. The right turn signal will still flash as it suppose to when i indicate the right turn signal. What's the problem here??
Help me out guys!
Thanks.
kteng
HID problem
Postby LOUIS_XIII_ » Sat Nov 07, 2009 10:56 pm
try switching the right side HIDs to the left side and vice versa to narrow your problem down to possible fault wiring
LOUIS_XIII_
Re: HID problem
Postby kteng » Sun Nov 08, 2009 1:54 am
LOUIS_XIII_ wrote:try switching the right side HIDs to the left side and vice versa to narrow your problem down to possible fault wiring
Thanks, ill give it a try.
kteng
Postby Gibson99 » Mon Nov 09, 2009 10:52 am
since it's just the corner light (which isn't HID) i would suspect a simple burnt out bulb. swap the bulbs from left to right and test before putting it all back together. $5 at autozone/oreilley/walmart will fix you up there... or spend $10 on the new silverstar corner bulbs that look blue/chrome when off but light up orange.
Gibson99
