SolaraGuy.com • View topic - 99 solara headlights
Postby kwan » Tue Nov 10, 2009 9:12 am
hey i have a problem with my 99 solara headlights they do not turn off so my hids are constantly on, is there a way to shut them off during the day??? even when i turn the headlight switch to off its still on
kwan
Postby kenny6683 » Tue Nov 10, 2009 10:19 am
you would need to disconnect all connections from the HID ballast and test your headlight wire seperately. If the power goes off when car shuts off then you know its your ballast which is giving off constant 12 volts or maybe you had wired up HID incorrectly with constant power from battery going to wrong wire
kenny6683
Postby 1gSE » Tue Nov 10, 2009 11:03 am
constantly on when the car is on....or constantly on after you release the parking brake?
Solara-M62 @ 5.5psi
1gSE
Postby CamryOnBronze » Tue Nov 10, 2009 1:52 pm
if constantly on while driving, it is your DRLs... just unplug the gray plug on the pas. side of the bay near the firewall and that should do the trick.
Postby kwan » Tue Nov 10, 2009 1:53 pm
hey guys thanks for the tips but i dont think it would be the hid connection because even before i had installed the hid the stocks bulbs did the same thing..... also the head lights stay on during the day when the car is on but when i turn it off the lights turn off
kwan
Postby kenny6683 » Tue Nov 10, 2009 2:18 pm
CamryOnBronze wrote:if constantly on while driving, it is your DRLs... just unplug the gray plug on the pas. side of the bay near the firewall and that should do the trick.
Damon...if he unplugs this wouldnt the headlight wire not receive power?
I thought he ment the headlights were on after car was turned off which is why i assume he had contant 12 v going to headlights...but anyways now I am curious about the DRL (daytime running lights) plug
kenny6683
Postby 99BlackSandv6 » Tue Nov 10, 2009 3:21 pm
If you have HIDs you need to disable the Daytime Running Lights. To do this, just disconnect the gray plug on the resistor located on the passenger side of the firewall under the hood. It is labeled with a caution sticker that says it is HOT. Also disconnect the light sensor, this is the dark dome shaped lens lookin' thing on the passenger side of the dash. If you pry up on it, it will pop out so you can unplug it.
These two plugs will disable your DRLs and your headlights will work properly. Also if you just unplug stuff, it is completely reversible.
Postby LEE337 » Tue Nov 10, 2009 3:37 pm
^The grey plug under the hood is the only plug needed unplugged to disable your DRL. The sensor on the dash just turns on your lights when it gets dark. I unplugged the sensor anyways so Im able to turn off my lights when its dark.
Postby kenny6683 » Tue Nov 10, 2009 3:55 pm
nice!!! learned something new lol
kenny6683
Postby 99BlackSandv6 » Tue Nov 10, 2009 4:33 pm
LEE337 wrote:^The grey plug under the hood is the only plug needed unplugged to disable your DRL. The sensor on the dash just turns on your lights when it gets dark. I unplugged the sensor anyways so Im able to turn off my lights when its dark.
You're exactly right. That's also why I did it on mine.
Postby SleeperSolara » Tue Nov 10, 2009 11:27 pm
Both you guys are correct.
I hated how my headlights would turn on in a long tunnel here in OKC.
So i unplugged the light sensor on the passenger side in the corner of the dash.
When you do that, and do the independent fog light mod you get this.
Postby kwan » Wed Nov 11, 2009 2:15 am
hey thanks guys very much for the help ill be sure to give it a try, ill let you guys know how it goes
these are my only current pictures i have for now ill post some new ones up later
also i was wondering how would i do the independent fog light mod??
thanks guys for your time :drinking:
kwan
Postby 99BlackSandv6 » Wed Nov 11, 2009 11:04 am
http://www.solaraguy.com/viewtopic.php? ... fog+lights
Follow this guide. I did the same thing but used an alternative 12 volt source so that the corner lights don't have to be on in order to have fogs on.
