SolaraGuy.com • View topic - NonStopTuning 1MZ Pulley Feedback, User Reviews, Comments
Postby NonStopTuning » Wed Nov 11, 2009 1:08 pm
Hi everyone!
So the NST 1MZ Crank Pulleys are finally in stock and on sale!
Many of you here joined our GB and should have your pulleys in hand within the next few days.
The purpose of this thread is for you to list your feedback regarding your NST Crank Pulleys installed on your cars. In addition, we will use this pulley to answer questions, share feedback, thoughts, and comments.
Those of you who own these pulleys, please share your reviews regarding performance. Before and after thoughts and comments will be valuable for all involved. I'm sure your fellow board members will appreciate your feedback.
We offer two pulleys for the 1MZ...
http://www.nonstoptuning.com/pKitToySol.html
NST00115 Underdrive Crank Pulley for naturally aspirated or turbocharged models. Requires the use of two new belts, belt numbers listed on our website. This pulley is roughly 60% lighter than your OEM pulley and underdrives your accessories by a modest percentage to provide you with better throttle response, hp, & tq numbers.
NST00199 CR-Lite Crank Pulley is designed for supercharged applications. This pulley does not slow any of the accessories and is compatible with the OEM belt. This pulley is roughly 60% lighter than your OEM pulley and will provide better throttle response.
Those of you who have installed your pulleys...
please share your feedback with us in this thread!
MIKE @ NST
www.NonStopTuning.com
NonStopTuning
Postby JamesT » Wed Nov 11, 2009 1:20 pm
NST00115 Underdrive Crank Pulley:
I've had no problems with this pulley. I like it a lot!
Even though it's an underdrive pulley, I've noticed very little change in my voltage on my SAFC II.
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby trd4life » Wed Nov 11, 2009 1:44 pm
HUGE difference in throttle response!
Postby DriDed » Wed Nov 11, 2009 3:14 pm
has anyone gone through a dyno to prove that the NST pulley actually freed up horsepower?
I know driving feel is important but so are the numbers as the NST lite-crank pulley is on my future mod list.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby Gregtrd » Wed Nov 11, 2009 4:42 pm
its not going to give that much hp gain, but lets the engine rev faster, to better use the existing hp
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby NonStopTuning » Wed Nov 11, 2009 7:36 pm
DriDed wrote:has anyone gone through a dyno to prove that the NST pulley actually freed up horsepower?
Good question. We have not done any specific testing with the 1MZ, but we have dyno charts and testing for many other applications.
Weight reduction in the rotating assembly always leads to better throttle response, quicker acceleration, better hp & tq delivery, and even better fuel economy when driving habits are kept the same.
Our latest dyno testing was with the NST CR-Lite (OEM SIZED) Crank Pulley for the BMW 335i. No, it is not a Solara, it is not a Camry. But the principles of weight reduction apply similarly, and the gains are noticeable...
We also tested the NST Pulley Kit on the Nissan 350Z HR engine earlier this year. The results were similar and positive...
NonStopTuning (NST) pulleys and kits are some of the best bang-for-buck modifications for your Toyota 1MZ engine. The gains are real and they are present across the entire RPM band. No other $150 modification can provide all these benefits in the low, mid, and high rpm range!
MIKE @ NST
NonStopTuning
Postby trd4life » Wed Nov 11, 2009 7:39 pm
Mike we need custom superchager pullies, a/c pulley, alt pulley, p/s pulley......
Postby NonStopTuning » Wed Nov 11, 2009 7:42 pm
trd4life wrote:Mike we need custom superchager pullies, a/c pulley, alt pulley, p/s pulley......
We have the ability to build custom pulleys of any type, and do so quite often.
I tried putting out a feeler for SC pulleys a couple months ago... very few people seemed interested in such a product. Unfortunately we can not mass produce a pulley if only two or three people are looking to buy it.
As I stated, we can build custom pulleys on a special order basis. Please feel free to contact us by phone and I would be happy to discuss a special order purchase with you.
Thanks again, good luck and have fun with all your projects!
MIKE @ NST
NonStopTuning
Postby DriDed » Wed Nov 11, 2009 7:47 pm
NonStopTuning wrote:NonStopTuning (NST) pulleys and kits are some of the best bang-for-buck modifications for your Toyota 1MZ engine. The gains are real and they are present across the entire RPM band. No other $150 modification can provide all these benefits in the low, mid, and high rpm range!
MIKE @ NST
Thanks for the dyno charts, I am gonna get lite crank pulley from NST definitely. I always go back and fourth deciding between an underdrive or a lite crank pulley, but the latter seems better right now as my belt looks perfectly usuable.
+TRD rear sway bar
DriDed
Postby ToyoSolV6 » Wed Nov 11, 2009 7:51 pm
Im picking this up tomorrow. hopefully i enjoy it after its done.
Postby DriDed » Wed Nov 11, 2009 8:08 pm
I got a question about the install of the crank pulley: are impact wrenches absolutely necessary in removing the crank pulley bolt? Would a torque wrench suffice?
**sips tea and eats a small piece of cake**
+TRD rear sway bar
DriDed
Postby ToyoSolV6 » Wed Nov 11, 2009 9:36 pm
I would say torque wrench should be perfectly good to remove it.
Postby JamesT » Wed Nov 11, 2009 9:48 pm
DriDed wrote:I got a question about the install of the crank pulley: are impact wrenches absolutely necessary in removing the crank pulley bolt? Would a torque wrench suffice?
Starter bump ftw!
BespokeAutoInterior
JamesT
Postby WUTANGCLAN » Thu Nov 12, 2009 11:56 pm
^x2 there's alot of torque on those bolts that even a standard impact wrench cant take off
WUTANGCLAN
Postby NonStopTuning » Fri Nov 13, 2009 1:29 pm
WUTANGCLAN wrote:^x2 there's alot of torque on those bolts that even a standard impact wrench cant take off
As others have said... the bolt holding the crank pulley is VERY tight, especially after having been on the pulley for several years, in most cases.
A very strong impact would be the best way to remove the bolt. You will need a torque wrench to install this bolt onto the new NST pulley after you have it installed.
Good luck everyone!
MIKE @ NST
NonStopTuning
Users browsing this forum: Google [Bot] and 14 guests
