SolaraGuy.com • View topic - Wiring diagram for Turbo timer "MAKE STICKY"
Postby DaveSolara » Sun Nov 29, 2009 5:13 pm
Here is another needed wiring diagram for Turbo timers. I used the Apex N/A and turbo timer. ECU pin outs and wire colors:
02 sensor wire from timer to ECU:
Black wire = pin 8 (2nd plug dwn - 28P) = 02 sensor input
Ground wire from timer to ECU:
Brown wire = pin 17 (4th plug dwn - 24P) = ECU Ground
Constant power from timer to:
White wire in igntion switch plug = constant power
Ignition 1 wire from timer to:
Black/yellow wire in ignition switch plug
Ignition 2 wire from timer to:
Black/red wire in ignition switch plug
Parking brake wire from timer to parking brake switch... self explanatory
2000 1/2 Solara V6 1mz 5sp
t3/t4 turbo
DaveSolara
