SolaraGuy.com • View topic - Whiteline Sway Bar Question
Postby vman5911 » Thu Dec 03, 2009 8:57 am
Would this whiteline sway bar fit the 2000 Solara SLE V6?
http://www.whiteline.com.au/product_det ... mber=BTR39
I'd prefer to go with the TRD, but I know those are discontinued.
Thanks
vman5911
Postby SleeperSolara » Fri Dec 04, 2009 12:17 am
Personally i would go wit the TRD RSB, you can still find them online.
Check wit Reggie, he should be able to hook you up wit one.
I think the TRD RSB on track settin' is "thicker" than the Whiteline rear sway bar.
Postby jetbtkng » Fri Dec 04, 2009 12:51 pm
whiteline is the best swaybar, 20mm compared to 19.1mm from trd, go with the whiteline, its the better bar.................... :drinking:
Postby CamryOnBronze » Fri Dec 04, 2009 2:31 pm
^ is the whiteline adjustable though? If not, the extra adjustment might be worth it, since .9mm is next to nothing. :lol:
Postby jetbtkng » Fri Dec 04, 2009 2:43 pm
actually they had 2 sway bars, 1 thats adjusable, 1 thats not, now i dont know if its still available, but they used to, as for the size, you can see the difference, its actually alot thicker, we put them side by side, the whiteline is definetey bigger............... :drinking:
Postby WhitelineJim » Sun Dec 06, 2009 3:36 am
G'day everyone,
Hope you don't mind us popping in to help here but just wanted to confirm that BTR39 in 20m is still a good number and is catalogued to suit Toyota Camry MCV20-SXV20-SXV23 97-02 and A-MCV30R 01-06. Not sure how that relates to the Solara range but we'd be happy to do add it in to the catalogue if we knew for sure.
The adjustable version of the TR39 series is no longer available unfortunately. Please let us know if we can do anything more to help.
Cheers
Whiteline Jim
WhitelineJim
Postby 02slera » Sun Dec 06, 2009 8:14 am
^^^maybe make the adjustable one available again....? hehe
2002 Solara SLE v6
02slera
Postby unbalancedwood » Sun Dec 06, 2009 8:28 am
WhitelineJim wrote:G'day everyone,
Cheers
Whiteline Jim
How much are bushings/hardware for BTR28Z shipped to Charleston SC 29403
unbalancedwood
Postby JamesT » Sun Dec 06, 2009 8:33 am
Whiteline Jim,
That model will also work for the MCV10/VCV10/SXV10.
The Solara Chassis code is the same as the 97-01 Camry (MCV20/SXV20) and the bar fits it.
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby CamryOnBronze » Mon Dec 07, 2009 8:48 am
It would be quite a trick if you could see a 3/100th of an inch difference by just looking at two sway bars. :lol: But I'm just messing with you- whiteline makes great stuff. I had a Whiteline RSB on my gen 3 and loved it, no complaints.
Postby 99BlackSandv6 » Mon Dec 07, 2009 10:54 am
I think that 1mm would actually be a fairly substantial difference. It's a 5.26% increase in diameter which would equate to more stiffness. And it's definitely enough to notice during visual comparison.
It would be cool to have another option for an adjustable RSB.
Especially since the TRD seems to have been disco'd. But I wouldn't be very interested in losing the adjustability of the TRD unit. I live in a snowy climate and it's nice to be able to soften the bar in the winter.
Postby CamryOnBronze » Mon Dec 07, 2009 1:33 pm
All I was getting at was that 0.9 mm is equal to 0.035 in. If I split 1" into 100 pieces, I don't think I personally could see the difference visually- that's all I was saying. :lol: It doesn't even matter really, I shouldn't have said anything. :lol:
Postby 99BlackSandv6 » Mon Dec 07, 2009 2:04 pm
I wasn't trying to start anything either Damon, haha. :lol:
Postby 02slera » Mon Dec 07, 2009 4:04 pm
well i painted my bar so its even thicker! LOL j/k i dont even have one hahaha c'mon WHITELINE get us an adjustable one thats 20.1mm!!! HOOK it up!
2002 Solara SLE v6
02slera
Postby bbq bob » Mon Dec 07, 2009 4:29 pm
i had gregtrd change my trd bar to a whiteline bar. laying on the ground side by side you can see the differance . the whiteline is configured a litte differant at the ends . looked as if the bar would contact the struts . after putting the car on the ground there was plenty of clearance.
bbq bob
