SolaraGuy.com • View topic - HID turning off after 2 min
Postby mazen222 » Sun Dec 20, 2009 7:06 am
My passanger side fog light is acting up. Driver side is fine.
a while back it wasn't turning on, so i had to turn the switch off and then back on 2-3 times and it will come on.
now, it turns on by itself but after 2 mins, it dims off. If i turn the switch off then back on, it will turn on for 20 sec and then dims again to off.
Has anyone experienced this before? i have feeling its loose wire or something but i'de like some feedback before i go underthere.
Thanks,
Mazen
1999, 5 Speed V6
mazen222
Postby TLMNICK » Sun Dec 20, 2009 9:11 am
Either your bulb or ballast is dead. Failing that, you might want to check all the connections. If it was just a "plug and play" kit, then those are notorious for that type of failure. Using a separate relay harness is always recommended so that you don't starve the ballast of current. If a ballast isn't getting the proper amount of current (steadily), it fries.
Also pull the bulb out. The little bubble in the center where the xenon gas is should be nice and clear for the most part. If it's grey or black at all, then you need a new bulb too.
TLMNICK
Postby LEE337 » Sun Dec 20, 2009 9:26 am
Lets start with what kinda kit you have?
(Pics if you have'm)
Is it plug n play??
Im guessing its plug n play...
A lot of times where you plug the OEM connection into the HID connection it gets corroded and nasty. That was one of the problems I had with one of my HIDs. The movement of the car would sometimes turn on and off the HIDs. Untill finally the bulb went out because of the constant on and off.
Turning it on and off repeatedly is not good for HIDs either. Thats the best way to blow out a bulb. :)
Hope this helps a bit...
Postby mazen222 » Sun Dec 20, 2009 2:45 pm
thx guys... it is plug and play... the one from vvme
they are crap! one balast got water in it, i got it replaced, then one bulb burnt out and now this sh!t
1999, 5 Speed V6
mazen222
Postby WUTANGCLAN » Sun Dec 20, 2009 5:13 pm
^go with mod-express they don't fail
WUTANGCLAN
Postby xavier » Mon Dec 21, 2009 11:48 am
mazen222 wrote:thx guys... it is plug and play... the one from vvme
Yeah, I had endless problems with my VVME kit. Ironically, I have the exact same problem as you describe. I got sick of it and went back to halogen. I think the problem resides in a faulty controller though...tap or jiggle the black box that all the wires feed into and see if that flickers the lights?
xavier
